    Belt seam
    7 Posts 3 Posters 666 Views 3 Watching
    • R
      reymond
      Hello
      can someone help me, how do I do best a seam around the belt?
      I've done manually with great effort.
      many thanks for the help
      Sketchup & Vray Trainer
      • mitcorbM
        mitcorb
        Hi, reymond:
        Perhaps you could try Chris Fullmer's Component Stringer? Otherwise, some would suggest making a texture with that much detail.
        The link to Chris's tool: http://forums.sketchucation.com/viewtopic.php?t=23616.
        Also, check in the plugins index under sdmitch--maybe.
        • R
          reymond
          thank your for the link.
          I've seen the tutorial. but somehow I get baked it. 😒
          can someone help me there?
          seam.skp
          • mitcorbM
            mitcorb
            I'm sorry reymond, but I cannot decipher the phrase "...get baked it." I do know that you must set the component in a particular orientation in order for it to be "arrayed" along the chosen path, or stringer.
            • R
              reymond
              or can I do this with a uv map? and if so, who can tell me how?
              • R
                reymond
                hmm ........ any ideas, help or other considerations?
                  Seems you can with the Shape Bender by Chris Fullmer 😉
                  It's not for a belt but that is same process 😄
                  http://sketchucation.com/forums/download/file.php?id=50706
