    Shadow Time Mismatch?
    12 Posts 2 Posters 743 Views 2 Watching
      Why doesn't the times match?
        Even when I change the timezone in SU ruby return the same number.
          I concur.
          ["TZOffset"] should return the offset from the TZ ???
          But it seems flaky - my default SKP template [geo-located in the UK] says '1.0' when I first list the shadow_info as an array, but if I try to extract it as above it returns '-0.0' ?
          The "ShadowTime" is always returned as 1 hour ahead of the displayed time 😕
          The setting for 'daylight-saving' seems equally useless... 😒
            Oddly enough I get the time I want if I do this: model.shadow_info['ShadowTime'].getutc
            Which is just odd... Probably just a coincidence with my computers TZ.
              I think you have it.
              It's reporting the time at GMT - you need to convert it to your [or your SKP's] local time...
              EDIT .gmt? returns false !
                How do you get that?
                  hmm...
                  Is SU returning the time in UTC?
                  And Ruby thinks it's local time - so it add's the computers TZ to the string?
                    No... this is all wrong... my brain melts to a mush of this...
                      Time.zone returns the time-zone that SketchUp thinks the SKP is in.
                      I think this 1 hour stuff is because the Daylight saving is etc false but the time.zone says it is in effect !
                        Perhaps Time.localtime
                        to your local settings ?
                        .gm and .utc do similar conversions, the latter converting to UTC [GMT?]
                          This will create a Time object with correct timezome offset from UTC:
                          <span class="syntaxdefault"><br />model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />modeltime </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">shadow_info</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'ShadowTime'</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">getutc<br />tz_offset </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">shadow_info</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'TZOffset'</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> 60 </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> 60&nbsp;</span><span class="syntaxkeyword">/&nbsp;-</span><span class="syntaxdefault">1<br />utc_time </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">at</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> modeltime</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_i </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> tz_offset </span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                          However, need to work out a reliable way to detect the mis-match in case it gets fixed in future SketchUp versions.
                            <span class="syntaxdefault"><br />model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br /><br />modeltime </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">shadow_info</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'ShadowTime'</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">unless modeltime</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">utc</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">  time </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">shadow_info</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'ShadowTime'</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">getutc<br />  tz_offset </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">shadow_info</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'TZOffset'</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> 60 </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> 60&nbsp;</span><span class="syntaxkeyword">/&nbsp;-</span><span class="syntaxdefault">1<br />  modeltime </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">at</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> time</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_i </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> tz_offset </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /></span>
