    Intersect this?
    8 Posts 4 Posters 574 Views 4 Watching
      See attached file:
      IntersectTest.skp
      There is a face and a group with some more faces.
      For the love of my sanity I cannot perform an intersection between the two the way I want it:
      I want to intersect the root face with the content of the group and have the intersecting lines appear in the group.
      (Mind you - I cannot make it intersect manually when I'm inside the group and try "Intersect Faces > With Model")
      • mitcorbM Offline
        mitcorb
        Hi, ThomThom:
        Is this related to that other thread with 2 pages of replies?
          This is in the dev zone so I imagine Thom wants this done via voodoo rather than hodge podge.
            Related yes - it was my original problem. But I found that even doing it via the SU UI yielded unpredictable result so I ran a thread in parallel for the UI intersection. Results in that might give clues to this.
              Actually, I want it all voodoo hodge podge.
                JuanV.Soler
                if you move it all to another place it does intersect ¡
                Edited : ... less is more
                  What place would that be?
                  Note this is a Ruby API question - I'm trying to find out a working code.
                    JuanV.Soler
                    It worked for me after I moved it all to another place in the space, randomly ,
                    not specifically to any place .
                    I thought it could give you a clue .
                    Thanks for answering .
