    Moving vertices and snapping
    8 Posts 4 Posters 536 Views 4 Watching
    • pbacotP
      If you are interested in looking at a problem I am having moving vertices to snap to another vertex, please see attached file, which is self-explanatory. It is related to this thread: http://forums.sketchucation.com/viewtopic.php?f=15&t=47990&p=430465#p430460
      [Edit: I should say, with other similar triangular shapes, there was no problem. Then I ran across this case. IDK what makes the difference yet.]
      Move Point -snap test.skp
      • cottyC
        cotty
        The same with me, I would have bet on the opposite πŸ˜•
        Or my computer is now infected with the first SketchUp virus? πŸ˜‰
        my SketchUp gallery
          Possible to see it in V6 ? πŸ˜‰
          • pbacotP
            Sure. How is this?
            v. 6 may work differently.
            Move Point -snap test 6.skp
            • beginnerB
              beginner
              Hi pbacot,
              Only a to b doesn't work for me.
              Rest is fine. I'm using auto-fold.
              I have noticed that you have snapping ON under Model Info -> Units - Sometimes it doesn't help.
              Move Point -snap test-beginner.skp
              Regards, SU 'beginner'
              • pbacotP
                @beginner said:
                Hi pbacot,
                I have noticed that you have snapping ON under Model Info -> Units - It doesn't help.
                Yep, just a to b is a problem for me too.
                • beginnerB
                  beginner
                  Draw the required line πŸ˜†
                    Seems difficult to move alone vertex with the Autofold (some capricious πŸ’š
                    For move some vertex without plugin
                    I draw an helper little segment and that is it that I move along inferanced lines + Autofold! πŸ˜‰
                    That avoid some headaches πŸ˜„
