    Ruby for transfering edges to curves needed...
    8 Posts 6 Posters 869 Views 6 Watching
    • artmusicstudioA
      artmusicstudio
      hello,
      has anybody a skp-ruby-script, which is able to smooth a polyline (circle / ellipse of edges) inserting more edges by interpolation while keeping the geometric form?
      i have sections threw a cylinder ( = ellipses of certain amount of edges, no radius), which i would like to make smoother for further boolean operations.
      thank you a lot.
      stan
      • sdmitchS
        sdmitch
        Stan, I have a "Spline" plugin on my blog. It does a spline fit interpolation through the end points of selected edges and creates a curve.
        http://sdmitch.blogspot.com/
        • gillesG
          gilles
          BezierSpline,
          http://forums.sketchucation.com/viewtopic.php?t=13563#p100509
          select the curve, (you may have to use Recurve http://forums.sketchucation.com/viewtopic.php?t=36822#p324196) right click and choose BZ-convert to/ catmull spline.
          • artmusicstudioA
            artmusicstudio
            hi, thanx, could not download for some reasons from your site...
            stan
              me too error 500 ๐Ÿ˜ฎ
              • fredo6F
                fredo6
                @artmusicstudio said:
                hello,
                thank you a lot.
                stan
                I have a plugin in preparation that do this sort of things (will be part of Curvizard).
                Could you post or PM me your model so that I check on a real case.
                Fredo
                • artmusicstudioA
                  artmusicstudio
                  hi fredo,
                  i was rather busy in last weeks.
                  well, my situation is the following:
                  i made a quick sketch and forgot to high up the amount of edges in the circles, before i started to twist them.
                  so after that i have my "sculpture" with lots of "edged" curves in 3d, nearly impossible to "recreate" from scratch again.
                  the idea was, that a polygon of more edges in 3d is analyzed and more edge-point are inserted to get a smoother curve in 3d AND eventually a polygon correction, if connected to this curve (the curve is part of a 3d object),
                  but inserting points not only by dividing the lines (such rubies are on the market) , but interpolationg the curve.
                  i will extract an example and send it to you tonight (with a sketch of this idea).
                  thank you so far!
                  regards stan
                  • Chris FullmerC
                    a 2d elipse or circle like you said int he first post is a VERY different beast than a 3d shape. Please try to not leave out important details like that ๐Ÿ˜‰
                    There are scripts that will subdivide 3d shapes like artisan or subdivideandsmooth. You could try those.
                    Subdivide - Free
                    http://www.smustard.com/script/Subdivide
                    Loop Subdivision - Free
                    http://www.guitar-list.com/download-software/sketchup-loop-subdivision-smooth-plugin
                    Subdivide and Smooth - $15
                    http://www.smustard.com/script/SubdivideAndSmooth
                    Artisan - $29 on sale right now
                    http://artisan4sketchup.com/
                    Though frankly, I'm not sure that subdivision will automagically make your model better. But it might be worth trying!
                    Chris
                    All my Plugins I've written
