    Not rendering
    renderpluginsextensions
    4 Posts 3 Posters 869 Views 3 Watching
    • V
      Valadhiel
      Hey there!
      I have read a similar (almost the same topic) somewhere, maybe even on this forum, so pardon me for reposting it maybe, but I am really helpless.
      My issue is this: When I start rendering a scene, I get a msg VRay is processing your scene, please wait; stays like that for a min or 2 and then it just returns to a normal screen, w/o any rendering or frame buffer window.
      Now, my file is around 200MBs. I even deleted all my materials via that Remove all Plugin, cus the Remove G/C didnt work for me.. even after that, there were no changes.
      I am using SU8 Pro and VRay 1.49 if I'm not mistaking; I have 8GB RAM, 6core AMD processor on 3.30GHz working on W7, SP1.
      Any suggestions/solutions? πŸ˜•
      • beginnerB
        beginner
        Valadhiel
        I can see few historic posts about similar problem...
        http://forums.sketchucation.com/viewtopic.php?f=322&t=47337&p=423505&hilit=VRay+is+processing+your+scene#p423505
        http://forums.sketchucation.com/viewtopic.php?f=322&t=46989&p=419995&hilit=VRay+is+processing+your+scene#p419995
        http://forums.sketchucation.com/viewtopic.php?f=322&t=45074&p=403015&hilit=VRay+is+processing+your+scene#p403015
        http://forums.sketchucation.com/viewtopic.php?f=322&t=40880&p=362174&hilit=VRay+is+processing+your+scene#p362174
        http://forums.sketchucation.com/viewtopic.php?f=322&t=31961&p=282028&hilit=VRay+is+processing+your+scene#p282028
        http://forums.sketchucation.com/viewtopic.php?f=322&t=29698&p=260361&hilit=VRay+is+processing+your+scene#p260361
        Regards, SU 'beginner'
        • R
          rspierenburg
          Have you tried rendering a very simple scene, say a default colored box just to see if that works? If it does then I would have to say the problem has to do with the model, if it doesn't work then I would suggest maybe uninstalling and reinstalling Vray.
          If it is your model you can try to open the exisiting model, select everything and copy it into a brand new sketchup file and see if that helps any. Also make sure you've selected the Default Visopt in Vray to ensure you dont have a problem using an older version visopt.
          Rob
          • V
            Valadhiel
            it works when i put some boxes and lights. I'm guessing it may the 1. the file size; 2. overlaping surfaces in the model.
            i decided to do it all over again, since none of the mentioned solutions worked for me.
            shame tho, if it's about the file size, SU developers should deal with that πŸ˜„
            ty for your help, though πŸ˜„
