    Add_face(edearray) not working?
    11 Posts 3 Posters 639 Views 3 Watching
      tafkab76
      In the Ruby API it says that youn can create a face by passing an array of edges as an argument:
      Entities.add_faceSketchUp 6.0+
      The add_face method is used to create a face. You can call this method a number of ways:
      entities.add_face(edge1, edge2, edge3, ...)
      entities.add_face(edgearray)
      entities.add_face(pt1, pt2, pt3, ...)
      entities.add_face([pt1, pt2, pt3,...])
      entities.add_face(curve)
      I tried it like this
      punkteArray = []
      edgeArray =[]
      punkteArray.push(Geom;;Point3d.new(0,0,0))
      punkteArray.push(Geom;;Point3d.new(100,0,0))
      punkteArray.push(Geom;;Point3d.new(100,0,100))
      punkteArray.push(Geom;;Point3d.new(0,0,100))
      edgeArray = ents.add_edges punkteArray
      face = ents.add_face(edgeArray)
      but that returned nil and no edges were drawn at all. I know that I could have used
      face = ent.add_face(punkteArray)
      but I was hoping to be able to create a face with a hole in it by passing an array with the outer and inner loop edegs to the add_face method, but not even passing a single loops seems to work.
        add_face( edges ) does work. I've used it lots of times. Even your sample code works.
        But...
        You cannot create with a hole in one go. Create the face first - without outer loop. Then take your inner loops and create faces for each of them - you then erase the face created with the inner loops.
        Btw - ents does that refer to model.active_entities ? Or did you use model.entities ?
          I didn't notice the add_face command at the end (it was below the code fold) But I'm seeing the same thing. I don't understand what's going on there... šŸ˜•
            tafkab76
            But I can“t see the face on your screen, only four edges?
            Here ist what it looks like when I execute the code on my machine. Maybe it“s a difference, because I use Ruby Code Editor?
            [xxl-img:xg9qtt3f]http://www.steffenblome.de/add_face.jpg[/xxl-img:xg9qtt3f]
            as you can see I used
            ent = mod.entities
            but I just tried
            ent = mod.active_entities
            with the same results.
            And thanks for that advice on how to create a face with a hole, I“m going to use that.
              Ah!
              When you created a set of edges with add_edges it didn't merge the start and end vertex.
              That prevented it from creating the face because it wasn't a closed loop.
              When I created a set of edges separately which where merged it did work.
              So the failure of add_face is a result of add_edges not merging crossing vertices.
                tafkab76
                Ok, I see. That also explains why find_faces didn“t work on neither of the edges.
                So add_face(edgearray) doesn“t work on API created egdes? Or is there a command that forces edges to merge to loops if possible?
                  It works if the edges are a closed loop.
                  I think if you create each face individually with add_edge it will work. Alternatively you can try to intersect the created edges with themselves.
                    But - in your case where you say:
                    You cannot create a face with holes in one operation.
                    @thomthom said:
                    You cannot create with a hole in one go. Create the face first - with the outer loop points. Then take your inner loop points and create faces for each of them - you then erase the face created with the inner loops.
                      tafkab76
                      Yes, I got that.
                      Thx!
                      • K Offline
                        krouza
                        @tafkab76 said:
                        Yes, I got that.
                        Thx!
                        You must use selection like this:
                        <span class="syntaxdefault">selection&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br />status&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add&nbsp;edges<br />&nbsp;&nbsp;<br /></span><span class="syntaxcomment">#&nbsp;Get&nbsp;an&nbsp;Array&nbsp;of&nbsp;all&nbsp;of&nbsp;the&nbsp;selected&nbsp;Edges<br /></span><span class="syntaxdefault">edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_all&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">kind_of</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge</span><span class="syntaxkeyword">)}<br />&nbsp;&nbsp;&nbsp;<br /></span><span class="syntaxcomment">#&nbsp;Try&nbsp;to&nbsp;create&nbsp;a&nbsp;Face&nbsp;from&nbsp;the&nbsp;Edges&nbsp;in&nbsp;the&nbsp;active&nbsp;component<br /></span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">nil<br />begin<br />&nbsp;&nbsp;&nbsp;&nbsp;face&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face&nbsp;edges<br />rescue<br />end</span>
                          You can get a type of entity faster by using grep. (See this thread: http://sketchucation.com/forums/viewtopic.php?f=180&t=48885 )
                          <span class="syntaxdefault"></span><span class="syntaxcomment">#&nbsp;Get&nbsp;an&nbsp;Array&nbsp;of&nbsp;all&nbsp;of&nbsp;the&nbsp;selected&nbsp;Edges<br /></span><span class="syntaxdefault">edges&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Edge</span><span class="syntaxkeyword">)&nbsp;</span><span class="syntaxdefault"></span>
