    Entities Edge color apply
    7 Posts 4 Posters 410 Views 4 Watching
    • K Offline
      krisjaniszakis
      Can some one say why this is working: (where 's2' is Sketchup::Edge entity)
      material_name=e2.material
      if mat
      cname=material_name.name
      else
      cname="<Default>"
      end#if
      but this is not working:
      material_name=e2.material.name
      After this code Ruby returns this error:
      Error: #<NoMethodError: undefined method `name' for nil:NilClass>
      Why i cannot strait forward access material name.
      • Dan RathbunD Offline
        Dan Rathbun
        Because the material() method returns a Sketchup::Material object, not a String object, But ONLY IF the entity has been assigned a material. If the entity has no material, then the material() method returns nil.
        This is standard operating procedure in Ruby. It is common to test using if, because in Ruby only false and nil evaluate logically false. Everything else, including 0, an empty Array and empty Strings, evaluate as logically true.
        So you do:
        if mat = e2.material()
          mat_name = mat.name()
        else
          mat_name = "<Default>"
        You cannot call .name() on the singleton NilClass object ( nil,) because it does NOT have a instance method called ' name'.)
        I'm not here much anymore.
        • K Offline
          krisjaniszakis
          Thanks it helped
            mat=e2.material
            if mat
              cname=mat.name ### OR .display_name ?
            else ### NO MATERIAL
              cname="<Default>"
            end#if
            test for the existence of the material and then get it's name if it exists, if the material is ' nil'then there's no ' name' to get.
              Dan Rathbun
              Late to the party πŸ˜‰
              • K Offline
                krisjaniszakis
                Thanks TIG there can be made changes in my code even more later πŸ˜„
                  @tig said:
                  mat=e2.material
                  > if mat
                  >   cname="<Default>"
                  > end#if
                  #display_name should only be used to output the name of a material to the UI - not as an id.
                  http://www.thomthom.net/thoughts/2012/03/the-secrets-of-sketchups-materials/#speaking-of-names8230
