    Arranging Toolbars in Sketchup for Mac
    7 Posts 5 Posters 2.0k Views 5 Watching
    • HelmiH Offline
      Helmi
      did anyone yet find a trick to have toolbars in the mac version of sketchup arranged in a more usable way than they work out of the box? These flying toolbars that don't care about your window size are annoying. πŸ‘Ž πŸ˜’
      I thought there might be a way that i just didn't find so far...
      Thanks,
      Frank
        driven
        I have tried most the 'toolbar builders' plugins, and written some of my own, but they all just add complexity.
        What I do now is 'nearly always' start SU with plugins 'disabled' and add sets of 'plugins', based on what I'm doing, with a modified version of Fredo's 'additional folders' ruby.
        I have my 'Save as Default' Template set with a 60 pixel margin where I can 'Park' toolbars.
        Also, I use lots of key shortcuts for my main tools, and Customise(by right-click) the top toolbar with useful SU tools that I don't use with shortcuts.
        I would like to be able to add 'tool button sets' to the same windowing system used for 'Entity Info', 'Styles', etc... but that's a Trimble thing.
        john
          Aerilius
          I assume that was maybe a design decision (due to multi document interface). I understand it can be very annoying with many 1-button toolbars. Maybe you could group icons together using Custom Toolbars?
          http://forums.sketchucation.com/viewtopic.php?t=10041
          However the plugin provides only default buttons and users have to add buttons for other plugins by digging in the code (search for UI::Toolbar and add_item). Unfortunately plugins do not easily expose their functionality to be implemented in alternative UIs, and SketchUp does not provide us programmatic access to all available tools.
          So there is a lot to whish and I am sure Trimble is willing to improve SketchUp. We only have to encourage the SketchUp team to do changes in the UI and convince them that the changes are good!
          • pbacotP Offline
            John,
            How do you do that? All files, including my template fill the screen on opening. I just saved a Template with a particular window size, but it just fills the screen when I open.
            Peter
              driven
              @pbacot,
              you choose 'New' to get your 'Template' the move the window across, after resizing the width, then
              'Save current window size'
              john
              • pbacotP Offline
                Doh! I never look down that far! or haven't for ages... 😳
                Thanks! Peter
                  applemango85
                  Has there been any headway made with the mac toolbar situation?
                  Has someone come up with a plugin that helps or is there now a way to group together the separate toolbars (the top custom toolbar line just isn't enough)
