    Remove the color/fill of a group
    7 Posts 4 Posters 3.3k Views 4 Watching
    • pep75P Offline
      pep75
      Dear SU-ppers!
      When I apply a fill to a group (not on purpose, but that happens sometimes...)...this has nasty consequences when I export the Collada model to Cinema4d(normals and maps are messed up). Okay, the best suggestion is not to apply a fill to a group, but does anyone know a plugin which removes 'group fills' and back-materials?!
      That would be great!
      Thanks in advance!
      grtz
      Pep
      • numbthumbN Offline
        numbthumb
        Change the default face colors (front and back) at Window > Style > Edit > Face Settings
        This plugin maybe: http://forums.sketchucation.com/viewtopic.php?p=102323#p102323?
        Comfortably numb...
        • pep75P Offline
          pep75
          Thanks NumbThumb,
          I'm going to try this tomorrow!!! β˜€
          • pep75P Offline
            pep75
            The Plugin works Numbthumb! Thanks!!!!
            • panixiaP Online
              panixia
              why do you need plugins for this?
              just select the group and open "entity info" dialog, click on the coloured square to open the "choose paint" window and tick "default"
                Yes, true, but you can have dozens or hundreds of such groups/components and even deeply nested. So what this plugin does is that it "simply" speeds up this process. Most (though not all) of the plugins "just" do this
                • panixiaP Online
                  panixia
                  yes i know πŸ‘
                  but i said that because in this particular case he specified he need to revert just some components which were eventually painted not on purpose..
