    Jagged lines on new Win 7 computer
    4 Posts 3 Posters 470 Views 3 Watching
    • M
      mikey r
      I just built a new Win 7 Ultimate 64 bit i5-3570k computer and the lines and axes on my models are jagged. My XP computer had straight lines. I'm using the same monitors and graphics card moved to the new machine. Same result with on board Intel graphics. Any suggestions?
      • mitcorbM
        mitcorb
        Just in case, did you check or uncheck hardware acceleration in Window> Preferences>OpenGL? Not sure if the jaggedness is a function of this? Or is it a Windows7 System setting at Control Panel>??Display?
        • GaieusG
          What Mitcorb says. If your video drivers are also up to date, under that OpenGL setting (if enabled at all), you should see some antialiasing settings like 0x, 2x, 4x - the higher you set, the smoother your edges are (and the slower SU is) 😄
          • M
            mikey r
            mitcorb & Gaieus,
            Ok I changed to 4x and now have straight lines. Thanks so much!
