    [Code] Open File Browser and Select File
    5 Posts 3 Posters 609 Views 3 Watching
    • J
      Jim
      This code opens a Windows Exlorer window with the given file selected.
      file = 'C;/Some/Folder/MyFile.rb'
      file.tr!('/', '\\\\')
      system("#{ENV['SystemRoot']}/explorer /n, /select,#{file}")
      Is there a Mac equivalent?
      • TIGT
        Just opening the file's folder with Sketchup's UI openURL will work cross-platform - PC and MAC... UI.openURL('file:///' + File.dirname(file)) [the file isn't selected though].
        • J
          Jim
          On Windows, calling openURL on a file can execute the file depending on whether the file extension is registered.
          This code just opens the file browser with the given file selected.
          • TIGT
            My code does not open the file, rather it opens the file's folder.
            Using openURL on a folder opens the folder in Windows Explorer...
            However, it doesn't highlight the file in either PC or MAC...
            • D
              driven
              Is this what you mean?
              Tig's code does open the file in 'Finder' and highlights the file title
              > file=("/Some/Folder/MyFile.rb") UI.openURL('file:///' + File.dirname(file)) true
              Like this it 'opens' in the associated program for that type of file. i.e. TextWrangler opens ruby files on my system.
              > file=("/Some/Folder/MyFile.rb") UI.openURL('file:///' + (file)) true
              This will also open in 'Finder'
              > file = './Some/Folder/MyFile.rb' system("open -R #{file}") true note: returns true/false
              > file = './Some/Folder/MyFile.rb' system %(open -R #{file}) true note: also returns true/false
              shorthand works as well
              >open -R './Some/Folder/MyFile.rb'`` note: NO return of true/false
              Without the -R recursive flag it will 'open' in the associated app
              Again, it can be with or without the return, dependant on the call syntax.
              john
