    [Code] Open File Browser and Select File
    5 Posts 3 Posters 433 Views 3 Watching
      Jim
      This code opens a Windows Exlorer window with the given file selected.
      file = 'C;/Some/Folder/MyFile.rb'
      file.tr!('/', '\\\\')
      system("#{ENV['SystemRoot']}/explorer /n, /select,#{file}")
      Is there a Mac equivalent?
        Just opening the file's folder with Sketchup's UI openURL will work cross-platform - PC and MAC... UI.openURL('file:///' + File.dirname(file)) [the file isn't selected though].
          Jim
          On Windows, calling openURL on a file can execute the file depending on whether the file extension is registered.
          This code just opens the file browser with the given file selected.
            My code does not open the file, rather it opens the file's folder.
            Using openURL on a folder opens the folder in Windows Explorer...
            However, it doesn't highlight the file in either PC or MAC...
              driven
              Is this what you mean?
              Tig's code does open the file in 'Finder' and highlights the file title
              > file=("/Some/Folder/MyFile.rb") UI.openURL('file:///' + File.dirname(file)) true
              Like this it 'opens' in the associated program for that type of file. i.e. TextWrangler opens ruby files on my system.
              > file=("/Some/Folder/MyFile.rb") UI.openURL('file:///' + (file)) true
              This will also open in 'Finder'
              > file = './Some/Folder/MyFile.rb' system("open -R #{file}") true note: returns true/false
              > file = './Some/Folder/MyFile.rb' system %(open -R #{file}) true note: also returns true/false
              shorthand works as well
              >open -R './Some/Folder/MyFile.rb'`` note: NO return of true/false
              Without the -R recursive flag it will 'open' in the associated app
              Again, it can be with or without the return, dependant on the call syntax.
