    Is this a ruby bug?
    5 Posts 3 Posters 667 Views 3 Watching
      tomot
      I'm creating a cross brace ruby, with left or right bracing options
      I wanted to use the keyboard "" to define the brace direction in the dialog box
      my plugins
      tomot
        Within double-quotes [""] in Ruby the back-slash \ has a special-power - it's the 'escape-character' - giving different meanings to some characters that might follow it.
        So to make a \ you must type "\".
        It's also used to make a " - as "1"" [making 1"]; or a new-line in a block of text - as "\n"; or a tab to format text - as "\t" etc.
        That's also why when typing PC paths in Ruby you must either use forward-slashes, or double-up your back-slashes, or use '' instead of ""...
        "C:/Temp/my.skp"
        "C:\Temp\my.skp"
        'C:\Temp\my.skp'
        The MAC always uses / anyway...
        This special-power for \ doesn't always work the same way inside single-quotes [''] - it only applies to \ to make a \ at the very end of a string, or ' to make a ' within a string; it does not apply to the other things like newline or tab that "" uses. So an alternative way of typing a \ could also be '\'
        πŸ€“
        EDIT: Corrected an error in the '' section 😳
          tomot
          great! "\" works, thanks for the explanation.
          my plugins
          tomot
            @tig said:
            As you see this special-power doesn't work the same way inside single-quotes [''] - so an alternative way of typing a \ would be ''
            This is not correct.
            '\' Error: #<SyntaxError: (eval):155: compile error (eval):155: unterminated string meets end of file> (eval):155
            \ is always an escape character. Even within single quoted string - because you might want to insert a single quote character. So within single quoted string you still have these couple of escape sequences: \' and \\.
            You can use different delimiters if you want to mix ' and " in a string without escaping:
            myString = %&This is "my" String&
            But beware that if you want to include your delimiter you must escape it:
            myString = %&This is "my" \& String&
            More info:
            http://www.techotopia.com/index.php/Ruby_Strings_-_Creation_and_Basics
              TT you are of course correct.
              Within '' only \' within a string and any final \\ are needed - for example \n doesn't apply as a newline.
              I've adjusted the original post to avoid further confusion πŸ˜’
