    How to make a triangle ring
    5 Posts 3 Posters 318 Views 3 Watching
    • B
      bigeye2012
      i try extrude by face, but it does not work
      follow me tool, does not work.
      is there any other tool , can bend a long cylinder into triangle shape?
      thank you.
      • GaieusG
        Why not? It should... Can you post the model?
        • B
          bigeye2012
          dear Gaieus:
          could you pls. check the model? thank you.
          triangle ring problem.skp
            The reason it didn't work is because it was so tiny. SketchUp won't make the tiny faces required. Scale the model up by a factor of a 100 or more, run Follow Me and scale back down.
            • B
              bigeye2012
              thanks to all
              scale large , really works
              also, i will try pipe by path.
              thank you ,everyone!
