    Guidelines
    27 Posts 6 Posters 1.8k Views 6 Watching
      rumcajs
      @dave r said:
      Why don't you put the castle on the ground plane? πŸ˜’
      I guess that I did not see that in video tutorial πŸ˜’
        rumcajs
        One more problem with that guidelines. Now I tried to hide the castle and I realize that when I change to different layer to hide the layer 0, so the guides, which I created will disappear πŸ˜„ So I need to clone the guide lines from layer 0 to active layer... Is that possible?
          Go back to the help files and learn about layers.
          And you don't need to use Layers to hide guidelines.
            rumcajs
            OK, I learned how to move them to different layer and how to hide them in Entity info box. I had seen in video, that the guy used hidding of objects very quickly in scenes video, but did not explain it how he did it.
              rumcajs
              Next problem... It looks that I will never finished the insert of the plan under castle...
              http://i46.tinypic.com/2rm0dhs.png
              I try to add guidline using tape (click and drag from red axis)
              but it disappears in the moment when I release the mouse button.
              http://i45.tinypic.com/4gbgi.jpg
                Press the Ctrl button. It toggles simple measuring and guide creation. Press it a couple of times and see if a small + signs appears/disappears. When it is there, it should create a guide line.
                  rumcajs
                  Yes, that is that what I tried few times. I succeed to create one guide line, but only one, not much success. I must train.
                  • 2 / 2
