    Deformation of object
    7 Posts 2 Posters 422 Views 2 Watching
      rumcajs
      Originally I had this model (note 90° degrees in the upper left corner).
      http://i48.tinypic.com/16awsc7.png
      Then I wanted to make the whole model looking more narrow, so I deformed the model. I replaced the buildings on right side for original ones and adjusted their position and angle. Now I have this problem with the upper building, because their angles are too odd. So I would want to deform them, but - how?
      This is original plan
      http://imageshack.us/photo/my-images/409/plan1.jpg/
      and this is what I have after deformation in actual point.
      http://i45.tinypic.com/vobb03.png
      For example, these walls need to be straight:
      http://i45.tinypic.com/am9pw7.png
      What would you do to correct them?
      • ToboboT Offline
        Tobobo
        How did you 'deform' the building?
        Was it with the scale tool?
        Toby
        Philippians 4:13
          rumcajs
          Yes
          • ToboboT Offline
            Tobobo
            @rumcajs said:
            Yes
            You would have been better to move the wall rather than use the scale tool.
            Scale will distort and deform everything selected and stretch anything joined to it.
            Toby
            Philippians 4:13
              rumcajs
              I know.
              • ToboboT Offline
                Tobobo
                I suggest that you scale it again in the opposite direction by the same value.
                Also if you cannot be bothered to formulate longer answers, you wont get people to help you.
                Toby
                Philippians 4:13
                  rumcajs
                  I start the project from point zero. Moderator can close this topic.
