    Plugins Quarantine
    5 Posts 4 Posters 135.4k Views 4 Watching
    • J
      Jim
      Here is a list of plugins that are known to be problematic in SketchUp. The purpose of the list is to provide a central resource to track buggy plugins. This will hopefully reduce some the many hours of frustration experienced by users, authors, and supporters of plugins. It goes without saying that if you install a quarantined plugin, you're going to have a bad time.
      There may be several reasons that a plugin may end up in quarantine:
      1. It crashes SketchUp.
      2. It changes the behavior of SketchUp in a way that is indistinguishable from a bug.
      Discuss this topic.
      List of Quarantined Plugins
      • [anchor=matchbox:29utfzb5][/anchor:29utfzb5]Matchbox_r1.1
        Reason: Changes the behavior of Array.* and Array.+
        Action: Removed download.
        Recommendation: Do not install this plugin; remove if installed.
        Files: MatchboxPlugin.rb, MatchboxPlugin/
      • [anchor=sketchyphysics:29utfzb5][/anchor:29utfzb5]SketchyPhysics
        Adds numerous methods to SketchUp's classes, most notoriously modifying Sketchup::Group#copy. Uses many global variables.
        Recommendation: Disable SketchyPhysics when not in use. To disable, "check" the Menu: Plugins > SketchyPhysics > Version > Disabled, then restart SketchUp
      • VirtualWind
        (Company closed.)
        Adds methods to SketchUp's classes; conlicts with progressbar.rb.
        Recommendation: Do not install. Remove or rename plugin files.
        Files: virtualwindPlugin.rb and VirtualWind/.
      • SketchUpBIM
        For invasive user interface - odd layer and camera behavior, conflict with the Lightup and other plugins. The SketchUpBIM topic is full of complaints.
      • Dan RathbunD
        Dan Rathbun
        [Candidate] for Plugins Quarantine**` %(#8000BF)[Plugin: Ambient Occlusion -> Simple Rays (sun, solar)
        File : "simple_rays.rb"
        Vers : NO VERSIONING (but there were at least 7 versions)
        Author: qpik
        Reason(s):]
        Extreme:
        • Modifies Ruby Base Classes
        • Modifies Trimble OEM API Classes
        Serious:
        • Not Author namespace wrapped.
        • Creates global methods for only it's own use`
        **Do not run as is!
        Causes BugSplat!****
        %(#008000)[****Many Issues fixed ... TESTING NEEDED:**** **[[Plugin] Qpik::SimpleRays OVERHAUL v1.x](http://sketchucation.com/forums/viewtopic.php?f)]**
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          [Candidate] Plugins Quarantine**` %(#8000BF)[Plugin: Cutlister
          Vers : 1.1, 1.2
          Author: Dana Woodman
          Reason(s):]
          Extreme:
          • (file: "utils.rb")
          • Array
          • Class
          • Float
          • String
          Serious:
          • (file: ALL)%(#BF4000)[Creates Many Toplevel Base Classes
          • needs Author namespace wrapping.] %(#008000)[Recommendation:
          • Load just before using
          • Do not use any other plugins after loading
          • Restart SketchUp when done using Cutlister]`**
          UPDATE:
          Dana Woodman (ishboo) posted a notice on Tue Jan 03, 2012, viz:
          Cutlister](http://sketchucation.com/forums/viewtopic.php?f)":13h7lrll]I sadly don't have much time or energy to work on Cutlister at this point. If someone wants to work on it, it is on Github and can be forked and modified ...
          I may have a look at it, to see what I can do to help solve some of the issues with this plugin.
          • kenK
            ken
            Did the Quarantine list become smaller? I remember a lot more plugins in this list. I had a question about a plugin that was quarantined, quarr_jsalign.rb and I was wondering just why this plugin was quarantined.
            I use this plugin all the time. To drop component/Group to a set elevation and just wanted to make sure just what it was doing to my Sketchup program.
            Now, I see the list is shorter and doesn't include this plugin. Am I looking in the right place or has the list been modified.
            Ken
            • thomthomT
              The logs list no edits for this thread. Just locks/unlocks, merge and bump.
