    Calculating external surface area
    14 Posts 7 Posters 4.5k Views 7 Watching
    • ashscottA Offline
      ashscott
      I need to calculate the surface area of some welded steel frames I have drawn in sketchup to calculate the cost of painting them - this means only the areas reachable with paint should be included.
      I thought perhaps there might be a plugin that could throw some kind of mesh over a model and give a relatively precise idea of the area I am talking about.
      Anyone know of anything or even have a workflow that could help me that is more efficient than selecting each face and going Context>Area>Selection and adding them up in a spreadsheet....?
      Just some stuff I do with Sketchup.
        Right click the material in the Material Browser and choose Area. Gives you the area of all the faces with that material.
        • ashscottA Offline
          ashscott
          Yeah that works well in a properly setup model. However, I have inherited these models from someone else. There was a plugin from SYCODE a while back that threw a mesh over a model for exporting the general shape to another CAD format - it didn't work that well but the idea of throwing a mesh over the model always struck me as a good way to do paint (surface area) calculations without accidentally including internal faces and faces that can't be reached for painting - they are out of sight or out of reach.
          • ashscottA Offline
            ashscott
            Here is a hacky kinda workaround:
            1)install this plugin (removes inner faces): http://forums.sketchucation.com/download/file.php?id=14434
            2)save the sketchup file you want to work on under a different name
            3)explode all the groups out of the model
            4)select all geometry in the model (Ctrl + A)
            5)go plugins > remove inner faces
            6)select all geometry again
            7)context click > area > selection
            Its not perfect but it has done the trick in my situation which had dozens of rolled hollow section beams intersecting each other.
              Aerilius
              That sounds similar like Outer Shell (?)
              • ashscottA Offline
                ashscott
                Yes but I found outer shell a little glitchy (probably using it wrong) - the plugin mentioned above worked with no hassles.
                • P Offline
                  pgarchnz
                  I am trying to calculate the external surface area of a curved bridge form. I see in a post from 2012 is was possible to get the area of a particular material. Is it still possible to do this in SU 2015? as I cannot find the reference or dialogue to enable me to get it.
                  Is there a simple way to get this information.
                  Thanks in advance
                  • ashscottA Offline
                    ashscott
                    Select a portion of the material in your model. Right click it and go Area > Material
                    It will display the area of that material in your current default units.
                    • erikBE Offline
                      erikB
                      There is a handy tool from fredo tools : report on areas.
                      It gives a nice report of all the areas in the file by material.
                      erikB
                      • JQLJ Offline
                        JQL
                        erikB
                        Beware of that because it doesn't (didn't sometime ago at least) report the right area if you have hole cutting components.
                        Example:
                        wall material is 10m2;
                        insert a window as hole cutting component with 1m2;
                        wall material will still read 10m2 and not 9m2 as it should...
                        www.casca.pt
                        Visit us on facebook!
                        • ashscottA Offline
                          ashscott
                          Yeah I made a terrific mistake calculating paint area on a construction job because the plugin I used was not behaving the way I expected. I can't remember which plugin it was
                          • fredo6F Offline
                            fredo6
                            erikB
                            Ooops! Completely forgot this case. Thanks for signaling.
                            I fixed it and will republish soon.
                            It will deduct the holes created by the glued components configured in Cut Opening mode
                            Fredo
                            • JQLJ Offline
                              JQL
                              Hi Fredo, I didn't see this post until today. Sorry and thanks!
                              I believe this to be a game changer for the way we use Sketchup at our office from now on.
                              I can't thank you enough!
                              www.casca.pt
                              • fredo6F Offline
                                fredo6
                                Thanks to tell me if this is OK now.
                                Remember that the surface deduction is only done when the component is in Cut opening mode.
                                Fredo
