    Toggle Construction geometry?
    7 Posts 3 Posters 511 Views 3 Watching
      I'm not finding anything that toggles the display of Construction geometry - missing or am I just blind?
        Sketchup.active_model.rendering_options['HideConstructionGeometry']
        ( dont like the Hide* prefixed type of settings )
        • TIGT Online
          What's more awkward about 'Hide*' any more than 'Show*' or 'Display*' ?
          ros=Sketchup.active_model.rendering_options
          if ros['HideConstructionGeometry']
            ros['HideConstructionGeometry']=false
          else
            ros['HideConstructionGeometry']=true
          Or use one of your one-line tests "? ||" or "=!"...
            I prefer to negate logic using the ! operator. The API is inconsistent and makes reading the code logic random.
            • TIGT Online
              Sketchup.active_model.rendering_options['HideConstructionGeometry'] =! Sketchup.active_model.rendering_options['HideConstructionGeometry'] would work logically too ? Doesn't it just reverse the current setting ?
                I mean in the way you read code.
                This article explains:
                http://truelogic.org/wordpress/2009/02/27/how-not-to-name-a-boolean-variable/
                • Dan RathbunD Offline
                  Dan Rathbun
                  I note there are 7 other settings that are positive, and begin with the prefix "Display".. and one positive that begins with the prefix "Show"...
                  The lack of convention is annoying.
                  I'm not here much anymore.
