    Installing Point at Center utiltiy
    2 Posts 2 Posters 981 Views 2 Watching
    • CardinalgaryC Offline
      Cardinalgary
      Following instructions from the Forum, I've gone to Sketchup Preferences and the extensions section and have checked the appropriate boxes to install the various tool bars, textures and tools. When I click "install extension" a popup box entitled "open" appears with Google Sketchup 8 in the folder box and a number of .skp files listed with the exception of a file entitled "carriage house" which is highlited. However, the "open" button is not highlighter nor operative. How do I get these extensions properly installed?
      I'll find those arc centers yet--with your much appreciated help. Thanks
        Under the extensions tab, you can only activate already installed extensions. These extensions are generally plugins written in a simple text format with a file extension *.rb (sometimes *.rbs) referring to the file type " ru by" (the scripting language of SketchUp plugins).
        Some more complex plugins may contain other file formats, too (like images for toolbar buttons) and are generally placed inside a *.zip archive that you need to unpack to the same place where you would install *.rb files.
        In SU 8, there is a possibility to rename this *.zip archive to *.rbz (or " Ru By Zip") and directly install the extensions/plugins with this "Install extension" button (i.e. you need not go to your Program files... > ... Plugins directory to manually copy/unpack files there). But you only use that button for these *.rbz files.
