    Exported file corrupted
    6 Posts 2 Posters 432 Views 2 Watching
      allison22
      My exported SketchUp 8 AVI animations that exceed 2 GB in size will not play on Realplayer or WMP. However, when I
      reduce the number of scenes and get the size under 2 GB, they play fine. Why is the size difference causing this problem ?
      • ToboboT Offline
        Tobobo
        AVI's are not the 'nicest' of file types because they don't deal with large file sizes that well.
        I export all my animations as single images and then use quicktime pro 7 to put the images together into a movie.
        What pixel dimensions are you exporting at?
        Toby
        Philippians 4:13
          allison22
          I used 1024x768 with 29.97 fps without compression. The smaller avi files that were not corrupted looked
          great after conversion to hi-res WMP format. Using any lower resolution is hardly worth looking at.
          • ToboboT Offline
            Tobobo
            It sounds like you have reach a file size ceiling.
            I would export as images if you want to go high or do shorter chapters and use an editing software to put them together.
            Toby
            Philippians 4:13
              allison22
              Yes, I've broken the animation down into 4-5 scene clips separated with transitions, and it looks ok this way.
              Thanks for you help.
              • ToboboT Offline
                Tobobo
                No worries, I found animations very temperamental.
                Toby
                Philippians 4:13
