    How to reset an incremental value used in an if statement?
    7 Posts 4 Posters 1.0k Views 4 Watching
      tomot
      I hope this attachment illustrates the issue:
      after the routine has run I want to reset @fix back to its original value of @fix = 60
      in order to run another if statement of a similar nature on another face.
      my plugins
      tomot
      • TIGT Online
        Why didn't you post the code snippet inside a 'code' block?
        It means we have to retype everything !!
        Anyway... after you have the
        @fix += @jmp1
        add something like this after the ' while...end'
        ` if @fix >= 432
        @fix = 60
        do other stuff ???
        end`
        or whatever you like...... πŸ˜•
        Only posting a selection is somewhat useless... πŸ˜•
        • Dan RathbunD Offline
          Dan Rathbun
          #default intermediate column placement
          @fix = @flenx/2-@fcol if not @fix
          startfix = @fix
          if ...
            # @fix gets changed here
          @fix = startfix
          # a new if statement here
          I'm not here much anymore.
            tomot
            thanks 2 both if u
            if @fix >=@flenx/2-@fcol
            fixed the issue πŸ˜„
            my plugins
            tomot
              @tomot said:
              thanks 2 both if u
              > end
              So what you really asked for was how to ensure a maximum value?
                tomot
                @thomthom said:
                @tomot said:
                thanks 2 both if u
                > > end
                NO! ...the original value @fix = 60 just happened to be the result of 2 user selected variables, @flenx & @fcol. When the "while..end" loop finished the value of @fix = 432 I now needed to reset @fix back to its original user selected value.
                I had been looking in the API, thinking there might be a 'reset' comment 😳
                my plugins
                tomot
                  Dan Rathbun
                  My solution is more readable. Let me rewrite it, thus:
                  resetfix =( @fix ? @fix ; @flenx/2-@fcol )
                  if ...
                  @fix = resetfix
                  # a new if statement;
                  if ...
                    # @fix gets changed again ...
                  @fix = resetfix
                  # ANOTHER if statement that may change @fix;
