    [Plugin] Divide Angle v1.0.1 20130621
    22 Posts 17 Posters 18.9k Views 17 Watching
      What do you mean by "install"? Did you just move the rbz file to the Plugins folder? What operating system?
        Assuming you have installed the .rb into your Plugins folder [somehow] and restarted SketchUp...
        Then please reread the tools instruction son the first post in this thread...
        It is NOT an Extension, just a simple tool.
        IT only works from the context-menu, and only appears if you have selected two lines that are suitable...
        I have reprinted the key paragraph below:
        Usage:
        Select two edges that are not parallel and that could intersect if they don't
        already share a vertex.
        Right-click to get the context-menu 'Divide Angle...'
        Note how this context-menu item is only available if the selection is appropriate.
        In the dialog enter the number of divisions + OK [default is '2'].
        It must be a positive integer [2 NOT 2.0]; otherwise you are prompted to retry.
        Also it must be 2 or more; otherwise there's an error message and it exits.
        Guide-lines are now drawn through the two selected edges and the division[s] as
        you have specified.
        The angle between the edges that is less than 180 degrees is always divided.
        • 2 / 2
