    Bender- helix
    7 Posts 3 Posters 325 Views 3 Watching
    • W Offline
      wantj43
      Helix-cone.pngI can not convert the cone to a helix shape. I can produce the desired results for an arc be not the helix. Any suggestions will be greatly appreciated.
      Thank you
      • numbthumbN Offline
        numbthumb
        Depending on how much you want to bend it, one possible solution would be to use Spiralizer: http://horo.ch/raytracing/tools/spir_en.html
        Then there is this thing: http://rhin.crai.archi.fr/rld/plugin_details.php?id=59
        Comfortably numb...
        • charly2008C Offline
          charly2008
          Hi Joseph,
          I can not explain why but for me it works fine. Try it once with the attached file
          Charly
          Untitled.skp
          • W Offline
            wantj43
            @charly2008 said:
            Hi Joseph,
            Charly
            Thank you Charly,
            I can the desired results with curves and other shapes but not the "helix". I can not get the program to recognize the helix as the second line selection. How are you generating the helix?
            Again, thank you.
            Joe
              charly2008
              It works, for example, also with a spherical helix.
                charly2008
                Hi Joe,
                the helix i generated with Drawhelix 14. The Helix has to be ungrouped!
                Charly
                • W Offline
                  wantj43
                  @charly2008 said:
                  Hi Joe,
                  Charly
                  Charly,
                  THANK YOU. The key apparently was "...has to be ungrouped!"
                  Joe
