    Ruby api - Get the thickness of component
    4 Posts 3 Posters 398 Views 3 Watching
    • N Offline
      nXqd
      Hi everyone,
      This is my very first post in this great forum. I encounter some problem when finding and using ruby api.
      What I want to do know is duplicate a component - (by selecting it using model.selection[0] ), and put the duplicated one on top of the original one. I have problem with find the x,y,z of a component in space and its thickness.
      I think this should be an easy issue for experienced sketchup users here 😎
        <drunkcode>
        <span class="syntaxdefault"><br />model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />instance&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">point&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">instance</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">bounds</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">corner</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">4</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">tr&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.new(&nbsp;</span><span class="syntaxdefault">point&nbsp;</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_instance</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">instance</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">tr&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
        </drunkcode>
          You have instance1.
          That has bounds.
          So to find its vertical extent use
          zz=instance1.bounds.depth
          Note that the three values for a bounding-box are counter-intuitive - following the old CAD conventions when z/depth was out of the screen - it's NOT the 'height' !
          So bounds
          .width >>> x Red
          .height >>> y Green
          .depth >>> z Blue
          You can also get its transformation
          tr=instance1.transformation
          Use that to insert your duplicate.
          instance2=instance1.parent.entities.add_instance(instance1,definition, tr)
          This now overlays the two exactly.
          To move the new instance up in the 'z' by ' zz' make a vector and apply a second transformation to it - you could apply it as you insert it BUT this is perhaps an easier way to get your head around...
          ve=Z_AXIS.clone ve.length=z tv=Geom::Transformation.translation(ve) instance2.transform!(tv)
          The second instance should now rise up so its bottom-most part aligns with the original's top-most part.
          • N Offline
            nXqd
            @TIG
            Thanks for the great long and damn useful answer. I will try it today πŸ˜„
