    Different volume in barrels
    7 Posts 4 Posters 419 Views 4 Watching
      AlexAle
      Hello to everybody. I am here for the first time looking for a solution to my problem:
      I created a wooden barrel in which I would like to calculate the volume of the liquid I can put inside at differnt heights. The barrel is posed in orizzontal way.
      The top solution should be to trace a mobile surface able to follow the inernal section of the barrel (that is not a cilinder), calculating the volume at single points (or 0,5 cm step by step).
      Is it possible in your opinion? If yes, suggestions or comments?
      Using sketchup vers. 8.0 freeware.
      hope I was clear in the exposition of the problem, thank you for attention and helpness
      waiting for answers soon
      bye bye
      • gillesG Offline
        gilles
        Make the inner volume a group it must be solid, edit the group intersect with an horizontal plane,delete unwanted geometries , the group must remain a solid, select the group and look at entity info to see the volume.
          AlexAle
          ty. but in this case I'll obtain the instant volume at the height of the intersected plan.
          If I have to calculate (per ex) 50 or more levels I need to create 50 different intersect planes deleting extra geometries all the time.
          I would need, but I don't know whether is possible, a solid volume able to change misures by "move botton" and following the barrel shape, in order to know how many litres I will have when the liquid is at 10 cm or 11 or 12 and so on.
          bye
            For something like that, I think I would do the math rather than doing it graphically in SketchUp. You can't modify the volume the way you need using Scale or the Move tool.
              AlexAle
              shame...as I supposed. I would like to make graphically the change of contents of the barrel, indicating the volume, but...
              Thank you a lot.
              • Jean LemireJ Offline
                Jean Lemire
                Hi folks.
                See these files:
                Progressive volume of a barrel.zip
                Click in sequence on the scenes tabs of the skp file.
                You can use the Excel file as a start to do the calculation.
                Just ideas
                  AlexAle
                  @jean lemire said:
                  Hi folks.
                  See these files:
                  [attachment=0:254czc31]<!-- ia0 -->Progressive volume of a barrel.zip<!-- ia0 -->[/attachment:254czc31]
                  Just ideas
                  Nice, Quite good. Tks Jean
