    Curved surfaces with Ruby
    8 Posts 3 Posters 1.2k Views 3 Watching
      alexmojaki
      I'm trying to understand how to work with curved surfaces in SU using Ruby. I'd like to, for example, get an array of face objects that make up a surface. The API documentation seems very poor as it says that Faces are flat polygons, but when I select the outside of a cylinder, the Ruby console tells me it's a Face object. I tried using add_faces_from_mesh, but it just splits the surface into one of the component faces and the remaining surface, and returns 0.
      • TIGT Online
        Make a cylinder.
        Have View > Hidden Geometry OFF.
        Pick the curved part.
        It selects as one object.
        Entity Info says it's a 'Surface'.
        Deselect it.
        Have View > Hidden Geometry ON.
        You can now see the facets making the surface.
        Pick a facet.
        Entity Info says it's a 'Face'.
        Faces that share common edge, where those edges are 'smooth' are part of a surface.
        Within Sketchup when hidden geometry is 'off' these select as a single object, take materials as a single thing etc...
        Within Ruby a 'surface' is not very much accessible.
        Its faces and edges etc are.
        There is one 'trick' surface using selections...
        selection.is_surface?
        This determines if the selection contains only all of the faces that are part of a single curved surface. Returns:
        True if the selection contains all of the faces that belong to a single curved surface.
        False if the selection does not contain all of the faces that belong to a single curved surface.
        Since a surface's faces are all connected and their shared edges are smooth? you can devise ways of getting all of the faces in a surface from one face in that surface...
        What is the intention of your code ?
          alexmojaki
          I'd like to know:
          All the points/vertices that make the surface.
          All the normals of the faces that make up the surface.
          I also want to be able to take a set of points and project them onto the surface, or rather find the intersection point between a ray and the surface.
          Your suggestion about connected faces is a bit vague. I would still need to be able to get one of the faces in the surface (without help from the user) and I don't know what makes an edge 'smooth'.
          • TIGT Online
            Starting at the end...
            Iterate the faces.
            edges=face.edges
            Iterate the edges
            edge.smooth? >> true or false
            An edge can also have .soft? and .hidden? true/false.
            To find all of the faces connected to a selected_face use
            connected_faces=selected_face.all_connected.find_all{|e|e.is_a?(Sketchup::Face)}
            To find all faces connected to the selected_face that are have a smooth edge and are thereby part of a common 'surface' you need to iterate the connected_faces in turn and their edges, testing for edge.smooth? and if so add that face to an array (which you kick off with surface=[selected_face]) unless it's already there, like surface<<face unless surface.include?(face) assuming a test tells us it has a smooth common edge. As you collect faces then face=surface[-1] so you keep moving out from the first face until no more faces are available/connected-smoothly...
            How are you 'getting' the face ? You say you don't want help from the user, BUT there must be some clue to 'get' it πŸ˜•
            If the user is preselecting it and hidden-geometry is off then that selection consists of all connected faces anyway ? So then selection.to_a should be 'all connected faces' ??
            Once you have the faces then their vertices are easy to collect.
            verts=[] faces.each{|f|verts<<f.vertices} verts.flatten.uniq!
            The array 'verts' is now all of the vertices used by the faces.
            Similarly the normals
            normals=[] faces.each{|f|normals<<f.normal}
            If you make the surface as a group then
            ray=model.raytest(point, vector)
            returns nil for a miss OR an array of a point and an array of what's been hit.
            To check that the hit is on the group use ray[1].include?(group) which is true if the containing groups is hit.
            A typical hit 'ray' might be something like [point3d, [group,face]]
            The hit 'point' is ray[0]
              alexmojaki
              THAT's what I needed! Thanks! I should have probably spotted that before, but I made a silly mistake in my experimentations with the console and got myself thinking that when I selected a surface, Ruby thought the whole thing was just one face.
                If you want to get a Surface - identical to how SketchUp defines with - when Entity Info display Surface - based on faces connected by soft+smooth edges when this snippet works: http://forums.sketchucation.com/viewtopic.php?f=180&t=41211#p365381
                  alexmojaki
                  Awesome! That snippet was exactly what I needed and it works great. Also glad to understand what soft and smooth edges are.
                  Thanks a lot!
                    For a detailed breakdown of what each property does (soft and smooth has very distinct functions) check out this article: http://www.thomthom.net/thoughts/2012/06/soft-vs-smooth-vs-hidden-edges/
