    How to get the center of a ComponentDefinition array?
    5 Posts 3 Posters 367 Views 3 Watching
    • lbsswuL
      lbsswu
      I have an array of ComponentDefinition. I want to find the center of these ComponentDefinitions.
      Maybe I should find the union bounds of these ComponentDefinitions, but I did not find the way πŸ˜• ... Could any one help me?
      • thomthomT
        I don't understand the question. ComponentDefinitions doesn't exist in modelspace - so I do not see how you would get the centre of a collection of definitions.
        Can you describe the abstract of what you are trying to do?
        • TIGT
          If you meant ComponentInstance then they each have bounds.
          Make a new empty bounding-box object [ bb], and then add each of the instance.bounds to that bb.add(instance.bounds).
          The center is bb.center.........
          • lbsswuL
            lbsswu
            I'm sorry I made a mistake, the type is not ComponentDefinition, but a Group. I use the following code:
            model = Sketchup.active_model;
            groups = [];
            model.definitions.each{|d| groups << d if d.group? }
            name = "left_head"
            pgrp = [];
            groups.each{|d| pgrp << d.instances[0] if d.instances[0].name==name }
            the type of gprp is Sketchup::Group.
            Actually, I want to get the center of a group with the group name "left_head", but there are several groups with the name "left_head", so I have to find the union bounding box of them.
            • lbsswuL
              lbsswu
              Thanks for your tip. I will test the code.
