    Unwanted line [RESOLVED]
    layout
    9 Posts 4 Posters 1.3k Views 4 Watching
    • W Offline
      Woodarc
      Snap1.jpgI have an unidentified line showing in my Layout view. Any suggestions as to why this might be? It does not appear in the SU model.
        Could be a lot of things. Not likely a bug. Can you post the LO file? It'd be almost impossible to tell without it.
          Some reason for open the bathroom door in that way ?
            It's a straighter line for the cats running up the stairs and jumping into the bath tub. πŸ˜„
            • W Offline
              Woodarc
              @woodarc said:
              [attachment=1:3txutw1m]<!-- ia1 -->Snap1.jpg<!-- ia1 -->[/attachment:3txutw1m]I have an unidentified line showing in my Layout view. Any suggestions as to why this might be? It does not appear in the SU model.
              File attached as requested
                Here's a screen shot from your model. The line is there right at the same Z (or at least extremely close to the same Z) as the section cut face which is highlighted in blue.
                After deleting the line in SketchUp, the problem was solved in LayOut
                PROPOSAL2.layout
                • W Offline
                  Woodarc
                  Many thanks. Sometimes you can't see the wood for the trees, it was a long day yesterday! I'll make a point of searching more thoroughly next time. Thanks again
                  • chrisglasierC Offline
                    chrisglasier
                    British Standard Code of Practice (Secondary means of exposure protection)
                    With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
                      Thx for the Infos πŸ˜„
