    Pollution Private methods of Class
    9 Posts 5 Posters 580 Views 5 Watching
    • fredo6F Offline
      fredo6
      Something strange I just noticed.
      All classes seems to have a lot of private methods which apparently derive from some existing scripts.
      For instance, if in the Ruby Console you just create an empty class
      class FooClass ; end
      ....and then check its private methods:
      FooClass.private_methods
      ...Then you get this long list, in which you have only a few Ruby built-in methods, all others coming from installed scripts:
      %(#0000FF)[chop!
      loop
      lambda
      printf
      FacesAreTriangles
      method_undefined
      private
      linestyletool2D
      In2DCircle
      method_missing
      untrace_var
      throw
      chop
      format
      sleep
      sign
      freehandtool2D
      extrude_test
      wd
      helix
      warn
      chomp!
      trap
      remove_instance_variable
      print
      NegIfEven
      texttool2D
      set_trace_func
      test
      GetPolyNormal
      chomp
      Equal2D2
      wp
      initialize
      global_variables
      load
      arctool2D
      wpp
      polylineedittool2D
      points_on_circle
      remove_method
      raise
      extrudeEdgesByLathe
      GetTransformedVertexPositions
      putc
      extrudeEdgesByFace
      Integer
      remove_class_variable
      OrderConnectedEdges
      CheckEntity
      GetFaceNormal
      getOffsetPolygon2
      PointInArray
      inherited
      local_variables
      require
      circletool2D
      extrudeEdgesByFaces
      undef_method
      require_all
      exit!
      scan
      fail
      attr
      GetCursorID
      CalcTriangleProperties
      puts
      class_variable_get
      Float
      create_face_from_selection
      join_edges
      GetAllVertices
      initialize_copy
      extrudeEdgesByEdges
      polygontool2D
      alias_method
      caller
      attr_reader
      simplyContours
      getOffsetPolygon
      gets
      class_variable_set
      String
      SelectAllConnected
      CountDuplicates
      line2cyl
      deBabelizer
      included
      VectorScalarMult
      facemakertool2D
      define_method
      InPlane
      extrudeEdgesByLoft
      exit
      fork
      LineFaceIntersection
      attr_writer
      readline
      PutsTransform
      singleton_method_added
      SimplifyCurve
      Array
      eval
      split
      extrudeEdgesByRails
      getc
      extended
      include
      isOdd
      getOffsetPolygon3
      hatchingtool2D
      tellPctComplete
      show_ruby_panel
      create_box
      callcc
      file_loaded?
      attr_accessor
      abort
      singleton_method_removed
      readlines
      zplane2D
      file_loaded
      IsAlreadySelected
      sub!
      binding
      syscall
      srand
      RemoveNonFunctionalVerts
      select
      GetVertsInWCS
      GetFaces
      method_added
      public
      extrudeEdgesByRailsByFace
      SegmentsCross2D
      fillettool2D
      extrudeEdgesByRailsToLattice
      make_pano_pm
      sub
      Equal2D
      at_exit
      p
      linetool2D
      extrudeEdgesByVector
      revolve_test
      iterator?
      singleton_method_undefined
      exec
      gsub!
      proc
      make_selected_components_unique
      rand
      TriangulateDelaunay
      open
      paramT
      remove_const
      method_removed
      protected
      adjusttool2D
      trace_var
      catch
      gsub
      block_given?
      system
      rectangletool2D
      inputbox
      sprintf
      add_separator_to_menu]
      I don't know where it comes from? I guess this is because these methods are created at Object class level.
      Fredo
      PS: I discovered this accidentally, because I wanted to call the private method "remove_method" from within a clas, but without success.
      • Dan RathbunD Offline
        Dan Rathbun
        No kidding! I (and others,) have been screaming about this for years? It's why we try to catch newbies, right away, and get them to code within their own module namespace.
        Yes.. when a script is loaded.. it is evaluated within TOPLEVEL_BINDING, which "is the particular instance of Object, called ' main'"
        So any instance vars, class vars, local vars, constants, methods, that are not wrapped in a namespace, are GLOBAL.
        We are fighting a losing battle against the poorly written Ruby examples, distributed by the SketchUp Development Team. Many of the examples are not namespace wrapped. Some of the extensions are not namespace wrapped (Sandbox Tools & ACT which is why I have them turned OFF.)
        You can use the boolean arguments to help filter out methods you do not wish to see:
        FooClass.private_methods.sort - private_methods(false).sort
        I'm not here much anymore.
        • fredo6F Offline
          fredo6
          Dan,
          Thanks. Here is the list of the alien methods in my Sketchup environment.
          Indeed, there may be others as I only use a few scripts.
          The command for getting the list in the Ruby console is
          (FooClass.private_methods & private_methods(false)).sort.join "\n"
          Fredo
          List of foreign methods inherited by all classes on Fredo6 machine
          CheckEntity
          CountDuplicates
          Equal2D
          Equal2D2
          FacesAreTriangles
          GetAllVertices
          GetCursorID
          GetFaceNormal
          GetFaces
          GetPolyNormal
          GetVertsInWCS
          In2DCircle
          InPlane
          IsAlreadySelected
          NegIfEven
          OrderConnectedEdges
          PointInArray
          PutsTransform
          SegmentsCross2D
          SelectAllConnected
          SimplifyCurve
          TriangulateDelaunay
          VectorScalarMult
          adjusttool2D
          arctool2D
          circletool2D
          create_box
          deBabelizer
          extrudeEdgesByEdges
          extrudeEdgesByFace
          extrudeEdgesByFaces
          extrudeEdgesByLathe
          extrudeEdgesByLoft
          extrudeEdgesByRails
          extrude_test
          facemakertool2D
          file_loaded
          file_loaded?
          fillettool2D
          freehandtool2D
          getOffsetPolygon
          getOffsetPolygon2
          getOffsetPolygon3
          hatchingtool2D
          helix
          initialize
          inputbox
          isOdd
          join_edges
          line2cyl
          linestyletool2D
          linetool2D
          make_pano_pm
          paramT
          points_on_circle
          polygontool2D
          polylineedittool2D
          rectangletool2D
          require_all
          revolve_test
          show_ruby_panel
          sign
          simplyContours
          tellPctComplete
          texttool2D
          wd
          wp
          wpp
          zplane2D
          • fredo6F Offline
            fredo6
            It seems to come from cases where Classes are declared directly at top-level without being enclosed within a Module.
            Fredo
            PS: I don't think Namespace generates a loss of performance (on the contrary, since evrything is hashed, it might be even be faster, as in each Module there is less symbol defined so that resolution is faster)
            • TIGT Online
              A lot of us, especially in the early days followed the examples in the API etc...
              Hence some of my earlier tools, like ExtendEdgesBy... are 'raw' and are still on the 'to do list' to get themselves module-ized... πŸ˜’
                Dan Rathbun
                initialize
                This is Object's default initialize method, which is always private, and inherited by all objects in Ruby. It's supposed to be there. If you DO NOT define an override in your class, then Object's gets used. So do not change or remove it. (And it should not have been changed by ANY script!)
                The following methods are from "Tools/sketchup.rb" and are supposed to be global methods (although I have argued that some of them belong in other modules, such as UI.)
                Could have gone in the UI module:
                inputbox (really should be replaced by a better/fixed UI.inputbox method)
                show_ruby_panel
                These ARE supposed to be global, and inherited by all modules and classes (in the same way that require and load is.)
                Therefor the API could have "legally" put them in the Kernel module:
                file_loaded
                file_loaded?
                require_all
                And then we would not need to require 'sketchup.rb' in every file.
                  Dan Rathbun
                  create_box
                  make_pano_pm
                  These come from the unwrapped Google/Trimble "Photo Textures" extension. You can turn it off through the Preferences dialog.
                  Also note, with this extension ON, the create_box Example will not work, because the Examples are also unwrapped.
                  • P Offline
                    pgarmyn
                    Maybee there can be another motivation to declare methods within a small namespace : they are loaded & executed faster
                      Jim
                      Sandbox Tools are responsible for most of them:
                      CheckEntity
                      CountDuplicates
                      Equal2D
                      Equal2D2
                      FacesAreTriangles
                      GetAllVertices
                      GetCursorID
                      GetFaceNormal
                      GetFaces
                      GetPolyNormal
                      GetVertsInWCS
                      In2DCircle
                      InPlane
                      IsAlreadySelected
                      NegIfEven
                      PointInArray
                      PutsTransform
                      SegmentsCross2D
                      SelectAllConnected
                      TriangulateDelaunay
                      VectorScalarMult
                      getOffsetPolygon
                      getOffsetPolygon2
                      getOffsetPolygon3
                      isOdd
                      paramT
                      sign
                      tellPctComplete
