    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] Ruby Console+ (3.0.2) – updated 30.10.2017
    61 Posts 18 Posters 38.5k Views 17 Watching
      Aerilius
      This is a powerful Ruby Console with IDE features like code highlighting, autocompletion and a code editor. It lets you open multiple independent instances of the console and remembers the command history over sessions.
      Version: 3.0.2
      Date: 30.10.2017
      Requirements: SketchUp 2014+
      http://sketchucation.com/plugin/812-ae_console
      https://sketchucation.com/pluginrepo/image/ae_Console/console.png
      Info from older version:
      The buttons have the following features:
      • Clear: Clears the console output
      • Reload: Once you have manually loaded a script (" load"), it will be automatically reloaded when the file is changed. In this menu you can select which files are observed for changes.
      • Binding: Allows to change the context in which a command is executed from global (TOPLEVEL_BINDING) to a specific Class or instance for easier debugging. This allows you to execute private methods or access private instance variables.
      • Select Entity: Allows you to click an Entity in the model to get a reference to it in the console.
        By holding ctrl when the main window is focussed, you can select points and by holding shift you can turn on inferencing.
        You can also assign an entity to a reference name of you choice, by typing & selecting the variable name and then selecting the entity.
      • Preferences: A menu to change color theme and font size and other settings.
      • Ctrl+Space: Triggers the autocompletion. This plugin uses Ruby's reflection methods to get relevant and accurate autocompletions from the live ObjectSpace (instead from a static file).
      • Snippets: The suggestions for autocompletion include Ruby code snippets, where you can quickly fill in using the tab key. Snippets can be edited in ae_Console/js/ace/snippets/ruby_sketchup.js
      http://i42.tinypic.com/nzrcyt.gif
      Demonstration of autocompletion
      History:
      version 2.1.2: 13.02.2014
      • fix for typeerror on first start
        version 2.1.1: 13.02.2014
      • workaround for JavaScript error messages in ace.js
        version 2.1.0: 12.02.2014
      • updated the ace editor to 1.1.2 (which fixes auto-resizing issues)
      • ace's autocompleter connected to SketchUp's Ruby interpreter
      • ace's snippets
      • file observer to reload files automatically
      • fix: now modifier keys in the SketchUp window work when the webdialog has focus
        version 2.0.1:
        version 2.0.0: 13.06.2013
      • more robust webdialog communication (should avoid corruption of settings)
      • saves history immediately and to a file and separate from the preferences. Thus issues with escaping and registry reading are avoided.
      • new architecture supports several independent instances of the console
      • added: Select Entity tool
      • removed: JavaScript mode because it had unsolvable issues
        version 1.0.10: 15.05.2013
      • better support of higher dpi settings
        version 1.0.9: 01.03.2013
      • icon added
        version 1.0.8: 03.11.2012
      • removed debug messages that were left over by mistake
        version 1.0.7: 27.10.2012
      • improvements for initialization
        version 1.0.5: 30.08.2012
      • now it tracks also script errors
      • better webdialog communication
      • input field resizes more reliably
      • inspector: highlights entities in the model
      • "repeat" button: allows to quickly repeat previous input without browsing too long in the history
      • after clicking buttons, the input field gains focus again
      • many optimizations
        version 1.0.2: 10.07.2012
      • minor change: validates data before using execute_script.
        version 1.0.1: 07.07.2012
      • G Offline
        glro
        i get error messages, and then the dialog box open but without the icons
        ae console error message
          Aerilius
          Fixed! (Packaging mistake)
            Anton_S
            Another Error
              Jim
              Aerilius,
              Nice console, thanks.
              Anton,
              Why have you by-passed the installer and put the plugin in the Tools folder? The Tools folder is for SketchUp to use and it is recommended not to put anything there.
              Start by removing the ae_Console files and folder from SketchUp's Tools folder, and install the plugin correctly using the Windows > Preferences > Extensions > Install Extension button.
                Anton_S
                @jim said:
                Aerilius,
                Anton,
                LOL, did you monitor my comp?? 😲
                Exactly, I have it in tools folder. The reason is do to having 3 plugins folders: plugins draw - fredo tools+tt_lib+more, plugins game - sketchy physics, plugins testing - my plugins. I rename one of folders to plugins whenever I feel to use one of them. I jst wanted to eliminate the loading of all "plugins", and use the plugins that I want instead of loading all plugins. For me, the tools folder is like the "main plugins". Ruby console, window settings... is a good place for them - cause I use them in all plugins.
                Well, anyways thanks for pointing that out: moving it to plugins
                  Aerilius
                  I didn't get that error. I then tested on another computer where I had tested the beta version and got the error.
                  You probably have the beta version installed and the registry (Sketchup 8\Plugins_ae\Console) contains an old/invalid value.
                  The script errors in IE are very pertinacious. I'll try to validate the configuration before passing it into the webdialog.
                    Anton_S
                    Hmm... it still gives me that error!
                    @aerilius said:
                    I didn't get that error. I then tested on another computer where I had tested the beta version and got the error.You probably have the beta version installed and the registry (Sketchup 8\Plugins_ae\Console) contains an old/invalid value. The script errors in IE are very pertinacious. I'll try to validate the configuration before passing it into the webdialog.
                    Errased, the beta, and all version, including this one, ran CCleaner, I guess I got it all removed using regedit, and it still gives me that error. How should error exist, when I cleaned-up after beta?
                      Aerilius
                      CCleaner doesn't do magic. I does a lot but I would be surprised if it (only) deleted HKEY_CURRENT_USER\Software\Google\SketchUp 8\Plugins_ae\Console.
                      The problem is that the only way to bring data from Ruby to SketchUp (execute_script) doesn't handle invalid data, it can't catch and suppress parsing errors.
                      I have a new version where I validate the data on the Ruby side before I pass it to the WebDialog. I'll upload it soon
                        Anton_S
                        @aerilius said:
                        ...upload it soon
                        That'll be great ❗
                          Aerilius
                          I uploaded a preliminary with the fix (1.0.2) to prevent this script error. I wanted to use my new webdialog communication system, but that isn't finished yet. It will come later.
                            Anton_S
                            @aerilius said:
                            I uploaded...
                            Good, good!! Thks πŸ˜„
                            • alexschreyerA Offline
                              alexschreyer Extension Creator
                              Ruby console on steroids! Very nice.
                              Cheers,
                              Alex
                              Author of "Architectural Design with SketchUp":
                              http://sketchupfordesign.com/
                                Aerilius
                                New features added:
                                inspector for SketchUp entities and many little improvements.
                                  Anton_S
                                  Thankyou, thnakyou, thankyou!!!
                                  I use it all the time πŸ‘
                                  • Dan RathbunD Offline
                                    Dan Rathbun
                                    I have sizing issues on XP w/ IE8 installed. (SU v8.0M4)
                                    I'm not here much anymore.
                                      Aerilius
                                      That is not (only) a sizing issue, the JavaScript does not run. Maybe something in the WebDialog-Ruby communication goes wrong and does not call the %(#000000)[initialize()] function?
                                        Reind Brackman
                                        Just installed Ruby Console+ and my productivity doubled already.
                                        Also very good to avoid RSI, better known as 'lets load the damn script again command...'
                                        Thanks - great work.
                                          cesaro36
                                          Could anyone solve this issue?
                                          Same Problem
                                            Aerilius
                                            What same problem? What browser? What version of the plugin?
                                            Can you try the latest version?
                                            • 1 / 4
