Tutorial on recording tutorials and presentations?
What recording software tutorials with screen zooming feature?
Maybe not yet time for tutorials because I have too little knowledge. Sometimes, however, to ask a question in the form of a film would be better than ten screenshots
What do you recommend? It can be paid but to have a zoom function recording the screen.
CamStudio tested but unfortunately I can not find a zoom function.
And what program do you use for post-production?
Regards,
I like Camtasia studio but you still have to edit the zoom feature when you edit the video.
Free BBFlashBack Express has not Zoom but very cool to use!
Version Pro have all that
139 β¬For tutorial another cool free one is Wink
(maybe there is a zoom inside) -
At the moment came to me something like that.
http://www.youtube.com/watch?v=5OCH913-Hv8&feature=plcpNot bad but ....
I hope I can somehow work out flashing lines. I asked the VirtualDub forum http://forums.virtualdub.org/index.php?s=4737001284e53b8e040746902e505b7d&act=ST&f=4&t=21105&st=0#entry90420
As for the problem is the flashing lines Sketchup. Because some frames lines disappear.
I hope you can fix it. I found inspiration here http://forums.sketchucation.com/viewtopic.php?f=18&t=654
For a while I was testing ZoomIt.
I am already on the tests. Here is what I have to choose.
- Presentation
When it comes to animation SketchUp is best in a 2x larger files and exports PNG without antialiasing. Then I used the film to create VirtualDub.
- Turorial
CamStudio tested, BB FlashBack Express is a Free Screen Video, and Microsoft Expression Encoder 4. The latter fell the most, and harvest most of the frames. Especially when it comes to capturing moving images.
I used to zoom in ZoomIt http://technet.microsoft.com/en-us/sysinternals/bb897434
It allows you to zoom enabled, drawing and notes while recording. Cool the solution but not quite perfect. At start up the mouse over the enlarged picture to us moving the mouse. You can not bring the area permanently.
If you have any other experience to facilitate the recording of desktop and presentation write boldly.
Example of use
An example of the use of BB FlashBack Express + ZoomIt
http://www.youtube.com/watch?v=1CIQNxZcp3UMicrosoft Expression Encoder 4 + ZoomIt
http://www.youtube.com/watch?v=Z3kc8qsXfMEIt seems that the encoder is better at capturing moving images. This is evident when capturing video.
Regards,
And what is the size file result BB flashback / Microsoft ?
File size is incomparable. BB records in its format and can save movie such as AVI. Encoder record in its format and writes to wmv. File sizes depend on the amount of compression, recording quality and the selected codec.
Recorded on video Encoder in wmv format, you can then convert to any format using free Any Video Converter http://www.avclabs.com/free-video-converter.php
It does not matter which program you record your desktop. Recording capacity depends on the quality and codec.
Regards,
Be careful with re-coding videos many times. It can drastically decrease quality (just like re-saving jpg images, no matter what compression you are using).
You are right. We must be careful because they will be losses. But only once you convert it is still acceptable.
Regards,
