    Animation will not render correctly
    renderpluginsextensions
    3 Posts 2 Posters 226 Views 2 Watching
      ljohnson_1
      I am having an issue that I have not encountered before rendering an interior animation. On the first pass, with do not render image all the frames render just fine, however after I save the IR and Light Cache and then load them using the from file setting the final passes come out in cyan and magenta colors. Not sure what is going on. I have done exterior animations before and it has worked just fine.
      • andybotA Offline
        andybot
        There's a bug with saved irrmaps. I posted a workaround that usually works
        here (registration required)
          ljohnson_1
          Worked like a charm, thanks for the quick response, it was really driving me crazy.
