    Plugin Help - modify Add Section Cut Face
    4 Posts 3 Posters 720 Views 3 Watching
    • bmikeB
      bmike
      I need a bit of help with TIGs 'Add Section Cut Face'.
      I want to limit my choices with the script, have it default to width of 2, unlocked group, do not hide edges, and fill be 'DarkGray'.
      I managed to get all the variables sorted - but I cannot get 'DarkGray' to default for color of the fill. I still get black:
       def dialog(sfix)
      ### get colours and layer
         model = Sketchup.active_model
         mlayers = model.layers
         alayer=model.active_layer
         model.active_layer=nil
         deflayer=model.active_layer.name
         model.active_layer=alayer
         dlayer = "CUT-"+sfix
          layers = []
           mlayers.each{|layer|layers << layer.name if layer.name != deflayer}
           layers=[dlayer,deflayer]+layers.sort!
           layers = layers.join('|')
         colours = Sketchup;;Color.names.join('|')
         cedges = colours ###v1.3
         colours = "<Default>|<No_Face>|"+colours ###v1.3###v2.5
         prompts = ["Cut-Face Color; ", "Cut-Edge Color; ", "Cut-Edge Width", "Keep Un-Faced Edges; ", "Hide Edges; ", "Lock Cut; ", "Cut Layer; "] ###v2.2/2.5
         title = "Section-Cut Parameters"
         @@colour = Sketchup;;Color.names[7] if not @@colour ### DarkGray
         @@edge = Sketchup;;Color.names[7] if not @@edge     ### Black
         @@width = 2 if not @@width
         @@edges = "No" if not @@edges ###v2.2
         @@hide = "No" if not @@hide ###v2.2
         @@lock = "No" if not @@lock
         @@layer = dlayer ### default
         values = [@@colour, @@edge, @@width, @@edges, @@hide, @@lock, @@layer]### ###v2.2/2.5
         popups = [colours, cedges, "", "Yes|No", "Yes|No", "Yes|No", layers] ###v2.2
         results = inputbox( prompts, values, popups, title )
         return nil if not results
         ### do processing of results
         @@colour = results[0]
         @@edge = results[1]
         @@width = results[2]
         @@width = 1 if @@width < 1
         @@width = 20 if @@width > 20
         @@edges = results[3] ###v2.2
         @@hide = results[4] ###v2.2
         @@lock = results[5] ###v2.5
         @@layer = results[6] ###v2.2
         if @@colour=="<No_Face>" ###v2.5
           @@edges="Yes"
           @@hide="No"
         end#if
         return true
       end #def dialog
      I think this is the relevant line:
      @@colour = Sketchup::Color.names[7] if not @@colour ### DarkGray
      I've played around with the 7 in brackets, it certainly changes the color... but i cannot find reference to how the colors are numbered... going to the materials palette brought back 0135, which is 'Moccasin'.
      Any help?
      mike beganyi design + consulting llc
      • TIGT
        ' 7' is 'Black' - find which number is ' DarkGray' - remembering that the list starts at 0...
        Hint - try ' 24' πŸ˜‰
        This one-liner in the Ruby Console lists all built-in colors and their 'index'...
        Sketchup::Color.names.each_with_index{|e,i|puts e+" = "+i.to_s}
        • bmikeB
          bmike
          Thanks much...!
          I tried counting in the list that pops up in the plugin, that didn't seem to correspond, then I went to the materials palette and learned that the numbers there don't seem to mean anything...
          All set now. Put in '24' and it is working fine.
          I can now just slide the layer toggle and I'm good to go.
          Makes for updating a document set much easier.
          • T
            the.pjt
            you are one of the best supporters ... when we want to modify a TIG's code which teacher is better than author himself ? πŸ˜„
