    [Plugin] Lamella Roofs
    63 Posts 25 Posters 52.4k Views 25 Watching
      johnminister
      @dave r said:
      Check under Security for permission. Are full permissions granted for all users?
      Do you have SketchyPhysics installed? If you look back through the thread you'll see that others found sketchyPhysics caused problems with this plugin.
      @dave r said:
      I just tested it on my Mac with SU2013 and it works fine. You didn't answer my question about having SketchyPhysics.
      Dave Thank for your help after disabling V-Ray rendering plugin the roof plug works fine.
      The Lamella plugin works great it's a pitty the hidden sample beam is not compleet with all uniek parts and Isolated from the rest.
      The workflow after opening the rubyconsole is not CNC conform. But overall it great tools for building one!
      Thank to Tim Warner.
        There are several 'rogue' plugins that interfere with legit plugins - often during some 'group' operations and/or 'entities' observers - this can cause the legit plugin to stall/fail or in the worse case result in the rogue bugsplatting...
        These are listed in a 'quarantine' list...
        In addition...
        SketchyPhysics
        Some versions of the recent Vray beta [I think the later versions are OK, so getting that installed might stop the 'clash' ?]
        Older versions of Podium?
        Some of the newer BIM tools which install overly aggressive observers.
        To test for these problem plugin[s] use the SketchUcation Plugins Manager to disable suspected files, and restart SketchUp so they no longer load. This way you can quickly find the problem[s] and leave them disabled...
        Then when you need to use a problem tool load it temporarily [orange button], when SketchUp restarts again that tool is again disabled.
        πŸ€“
        • F Offline
          Fred01
          Dear Tim,
          Im an old fart just looking for old school equations for lamella roof construction, ie formulae for timber member outer radius , length ,end bevel angles etc given a roof width and height, cant find anything under Zollinger or Junkers.
          Regards,
          Fred
          • 4 / 4
