    [Plugin] Lamella Roofs
    63 Posts 25 Posters 52.2k Views 25 Watching
    • Q Offline
      qn
      Excellent...
        johnminister
        Some help please?
        Error after running ruby?
        lamella_roof
        Error: #<NameError: undefined local variable or method `lamella_roof' for main:Object>
        (eval)
        Sounds simple to solve but how?
          Check under Security for permission. Are full permissions granted for all users?
          Do you have SketchyPhysics installed? If you look back through the thread you'll see that others found sketchyPhysics caused problems with this plugin.
            johnminister
            The plugin Lamella_roof is not working at all under the new Sketchup pro 2013.
            Sketchup itselve stops completely.
            I had no problems with Sketchup 8!
            Has anyone else the same experiance when upgrading to version 2013?
              johnminister
              @johnminister said:
              Some help please?
              lamella_roof
              (eval)
              Thanks Dave, I install sketchpro 8 back and it is working.
              Has someone used it win Sketchpro 2013? It's not working?
                johnminister
                Still not working in a clean 2013, it is in sketchpro 8?
                Got a complete hangup with a error report back and had to start sketchup again.
                  I just tested it on my Mac with SU2013 and it works fine. You didn't answer my question about having SketchyPhysics.
                    johnminister
                    Dave,
                    As I wrote I had a clean install which is not holding any plugins except the roof one.
                    It was working in windows sketchup 8 and not in 2013.
                    After excuting the roof plugin sketchup was more sketchdown.
                    I was asked to send a error file thats it.
                      johnminister
                      Dave Thank for your help after disabling V-Ray rendering plugin the roof plug works fine.
                      The Lamella plugin works great it's a pitty the hidden sample beam is not compleet with all uniek parts and Isolated from the rest.
                      The workflow after opening the rubyconsole is not CNC conform. But overall it great tools for building one!
                      Thank to Tim Warner.
                        There are several 'rogue' plugins that interfere with legit plugins - often during some 'group' operations and/or 'entities' observers - this can cause the legit plugin to stall/fail or in the worse case result in the rogue bugsplatting...
                        These are listed in a 'quarantine' list...
                        In addition...
                        SketchyPhysics
                        Some versions of the recent Vray beta [I think the later versions are OK, so getting that installed might stop the 'clash' ?]
                        Older versions of Podium?
                        Some of the newer BIM tools which install overly aggressive observers.
                        To test for these problem plugin[s] use the SketchUcation Plugins Manager to disable suspected files, and restart SketchUp so they no longer load. This way you can quickly find the problem[s] and leave them disabled...
                        Then when you need to use a problem tool load it temporarily [orange button], when SketchUp restarts again that tool is again disabled.
                        πŸ€“
                        • F Offline
                          Fred01
                          Dear Tim,
                          Im an old fart just looking for old school equations for lamella roof construction, ie formulae for timber member outer radius , length ,end bevel angles etc given a roof width and height, cant find anything under Zollinger or Junkers.
                          Regards,
                          Fred
                          • 4 / 4
