    Right click axis show errors in ruby console by plugins
    5 Posts 2 Posters 448 Views 2 Watching
    • dukejazzD Offline
      dukejazz
      Just by right clicking on axis for it's context will show errors in a open ruby console, cause by some ruby loaded plugins.
      Is this just my sketchup setup only or do some one else's with alot plugins see this too?
      I had a page and haft of error ... I unloaded 6 plugins and still have one left to find.
      Error: #<LocalJumpError: unexpected return>
      (eval):107:in `load'
      Why dose this happen? (must be bad code or conflick)
      • dukejazzD Offline
        dukejazz
        Example
        The loaded plugin zorro2.rb
        D:\P\Google\Google SketchUp 8m3\Plugins\Zorro2.rb:650
        (eval):107:in `call'
        (eval):107
          That's usually a result of people using return to exit a block instead of break.
          • dukejazzD Offline
            dukejazz
            @650 return method 647-656
            UI.add_context_menu_handler {|menu|
            	sel=Sketchup.active_model.selection.first
            	menu.add_separator
            	return if not sel
            	if sel.class==Sketchup;;SectionPlane
            			menu.add_item("Slice Model at Section") {Zorro2Tool.new.slice_model_at_section(sel)}
            			#menu.add_item("Slice Context at Section") {}
            Ruby console pannel show
            %(#8040FF)[Error: #<LocalJumpError: unexpected return>
            D:/P/Google/Google SketchUp 8m3/Plugins/Zorro2.rb:650
            (eval):107]
            @650 break method 647-656
            	menu.add_separator
            	break if not sel
            %(#FF4040)[Error: #<LocalJumpError: break from proc-closure>
            D:/P/Google/Google SketchUp 8m3/Plugins/Zorro2.rb:650:in `call'
            (eval):107return]
            sel = nil
            Both block methods fail?
            Thomthom you know more than I.
            by thomthom on Mon Jun 18, 2012 2:15 am
            That's usually a result of people using return to exit a block (true)
            so by getting rid of return line (#return if not sel)
            and adding to the 651 line if statement (and is sel)
            	menu.add_separator
            	#return if not sel
            	if sel.class==Sketchup;;SectionPlane and is sel
            This seem to fix the zorro2.rb code.
            Thank you, for your help, Thomthom on Mon Jun 18, 2012 2:15 am -jwc
              Replace this:
              return if not sel if sel.class==Sketchup::SectionPlane
              With this:
              if sel && sel.class==Sketchup::SectionPlane
