    [Plugin] Script selects the line or face.(UPDATED 15/02/16)
    26 Posts 15 Posters 22.0k Views 15 Watching
      snakeysnape
      Thanks sdmitch,
      Thanks also to Sahi hope you don't feel bad we've 'hijacked' your plugin.
      • P Offline
        Pu
        not work. (sketchup 2014)
          clausgs
          @sahi said:
          The script selects the line or face.
          The first icon >> click on it - and only the lines stand out >> again click on it >> disables script
          The second icon >> click on it - and distinguished only by persons >> again click on it deactivates the script >>
          [attachment=0:7ckaz2yc]<!-- ia0 -->selection_edge.zip<!-- ia0 -->[/attachment:7ckaz2yc]
          Hi Sahi
          Have used this plugin for a long time, but now it do not work in SU 2015 ?
          Can you fix that?
          Thanks for your great support...
          Claus
          ClausGS
            driven
            @Claus,
            if you open the file in notepad++ and find and replace...
            if you have the original version
             sel.each
            to
             sel.to_a.each
            or if you have sdmitch [faster] version
            sel.grep
            to
            sel.to_a.grep
            this works in v2015 for me...
            john
            • H Offline
              HirokaMatsuiko2015
              thank you for this tool im using it right now
              if its possible to request
              add shortcut keys with toggling selection tool
              right now when paradigm or changing between tools i need to hit ( Face Select > Spacebar ) or ( Edge Select > Spacebar )
              i think its more convenient in one keys
              like for example if hit X key it will also toggle the selection keys
              similar to other 3D software
                sahi
                Updated the plug-in in the first message
                • 2 / 2
