    [Plugin] Script selects the line or face.(UPDATED 15/02/16)
    26 Posts 15 Posters 23.8k Views 15 Watching
    • sdmitchS Offline
      sdmitch
      The code
      edges=sel.grep(Sketchup;;Edge); sel.clear; sel.add edges
      works in SU2014 but causes a stack error that crashes SU8.
      http://sdmitch.blogspot.com/
        driven
        @sdmitch said:
        The code...
        on mac both
        sel=Sketchup.active_model.selection
        edges=sel.grep(Sketchup;;Edge).to_a; sel.clear; sel.add edges
        work in v8 and v2014
        • sdmitchS Offline
          sdmitch
          Apparently my v8 is different because it still crashes with that addition.
            driven
            my test file had less than 2000 edges so is it a limit?
            • sdmitchS Offline
              sdmitch
              No I was using a small sample consisting of 3 or 4 faces.
              I did find a solution that works in both SU8 and SU2014 and that was to remove the observer before processing the selection and add it back after while using the selection processing code previously posted.
              	def onSelectionBulkChange(selection)
              		Sketchup.active_model.selection.remove_observer self
              		get_selection_edge(selection) if(@select_edge)
              		# get_selection_edge_smooth(selection) if(@edge_smooth)
              		get_selection_face(selection) if(@select_face)
              		Sketchup.active_model.selection.add_observer self
                snakeysnape
                Hi Sdmitch,
                Sorry but can you post the fixed plugin in here? I am confused as to where to put the selection code.
                thanks
                • sdmitchS Offline
                  sdmitch
                  @snakeysnape said:
                  Hi Sdmitch,
                  thanks
                  With apologies to Sahi.
                  selection_edge.rb
                    snakeysnape
                    Thanks sdmitch,
                    Thanks also to Sahi hope you don't feel bad we've 'hijacked' your plugin.
                      Pu
                      not work. (sketchup 2014)
                        clausgs
                        @sahi said:
                        The script selects the line or face.
                        The first icon >> click on it - and only the lines stand out >> again click on it >> disables script
                        The second icon >> click on it - and distinguished only by persons >> again click on it deactivates the script >>
                        [attachment=0:7ckaz2yc]<!-- ia0 -->selection_edge.zip<!-- ia0 -->[/attachment:7ckaz2yc]
                        Hi Sahi
                        Have used this plugin for a long time, but now it do not work in SU 2015 ?
                        Can you fix that?
                        Thanks for your great support...
                        Claus
                        ClausGS
                          driven
                          @Claus,
                          if you open the file in notepad++ and find and replace...
                          if you have the original version
                           sel.each
                          to
                           sel.to_a.each
                          or if you have sdmitch [faster] version
                          sel.grep
                          to
                          sel.to_a.grep
                          this works in v2015 for me...
                          • H Offline
                            HirokaMatsuiko2015
                            thank you for this tool im using it right now
                            if its possible to request
                            add shortcut keys with toggling selection tool
                            right now when paradigm or changing between tools i need to hit ( Face Select > Spacebar ) or ( Edge Select > Spacebar )
                            i think its more convenient in one keys
                            like for example if hit X key it will also toggle the selection keys
                            similar to other 3D software
                              sahi
                              Updated the plug-in in the first message
                              • 2 / 2
