    Window location
    4 Posts 3 Posters 347 Views 3 Watching
      bgtorque
      Hi all
      I have a twin monitor set-up on my Dell Vostro laptop and run the main SketchUp window on the 2nd monitor screen. However, any of the windows that I switch on, Layers, Components, Materials, etc open on the main laptop screen. I can move those windows about on the main screen but I cannot get them to move to the 2nd monitor screen, it is like there is a barrier there stopping them from moving over.
      Can anyone help me with the reason behind this and a solution?
      Thanks for your time..
      Ben
        bgtorque
        I take it there are no answers to this one? I'll assume it's a trick of the graphics card I guess.......
          mwm5053
          It's probably the way you have the dual monitors setup in Windows. I did the same with an HP laptop. They should be setup in extended mode in display options dialoge window this article explains a little better.
          http://it.scu.edu/howto/Dual_Monitor_Mode.shtml
          2011 iMac
          SU 2015 Pro, 2017 Make
          V2 Twilight
          macOS Sierra 10.12.5
            jim smith
            The first time I hooked up an external monitor, I had the same trouble, I couldn't drag anything left to right from my lap top to the secondary. Then realized I had my laptop on the left and the secondary on the right, but in the control panel, I didn't notice that I had my secondary monitor on the left side and laptop on the right. Just identify and make sure they are oriented to match the 1--2 on the monitors and the control panel. Sounds elementary but sometimes the best answers to frustrating issues are the most obvious.
            "Out of clutter find simplicity,
            from discord find harmony,
            In the middle of difficulty lies opportunity"
            Albert Einstein
