    Adjusting Round Corners radius value
    4 Posts 3 Posters 506 Views 3 Watching
    • N Offline
      neuex
      Hello there SketchUcation, I have a question for you.
      I am using LibFredo's Round Corners plugin. I just made a model and rounded off hundreds of corners. I saved and turned everything off for lunch. I then realized that I needed them to be slightly bigger.
      Is there any way to adjust the radius values or am I boned?
      thanks
      neuex
        Sadly I think that you are indeed screwed.
        Lesson... always make an 'archived backup copy' of your SKP before doing any major changes; that way you can revert to the earlier version, after the event - it's only a a few seconds and a tiny bit of disk-space - better than the alternative. πŸ˜’
        • N Offline
          neuex
          Excellent.... Thanks anyways
          • erikBE Offline
            erikB
            If you haven't saved it twice you can always rename the skb file to skp and you have the previous saved version.
            greetings, erikB
