    Solid Tools stay greyed out
    4 Posts 3 Posters 3.3k Views 3 Watching
      Rob Figee
      Hi, I created two solids by push pulling a square. Selected them and turned each into a group. Object properties says they are solids. I moved one a bit into the other to subtract them, but the solid tools ( except for the first one) stay grey.
      What am I doing wrong?
      Thanks in advance for your reply,
      Rob
      • jeff hammondJ Offline
        jeff hammond
        I assume you have SU free.. solid tools are a pro feature. (except outer shell)
        dotdotdot
          Rob Figee
          Thanks, that explains it.
          Rob
            Here is a quite inexpensive alternative: http://www.smustard.com/script/BoolTools
            And here is a free alternative (although I know that "strictly physically speaking" you cannot alternate between three things but only two): http://forums.sketchucation.com/viewtopic.php?t=14773
            This latter says "for SU 8" so either upgrade to SU 8 or upgrade your forum profile: http://forums.sketchucation.com/ucp.php?i=profile&mode=profile_info
