    Shadow String Fix.....fails in LO
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    6 Posts 2 Posters 11.1k Views 2 Watching
    • C
      Charlie__V
      Hey all,
      Selecting shadow string fix in SU corrects shadows in SU only. (see attached)
      Also, shadow strings present in exported .pdf's.
      Anyone else concur?
      Thanks,
      Charlie
      Shadow_String_LO_Screenshot
      Shadow_String_SU_Screenshot
        That just means the wind is blowing very hard past the cupola. πŸ˜„
        Actually I haven't seen that but I'll try to take a look at it when I get home from work.
        • C
          Charlie__V
          Dave.........how do you know it's the wind blowing.......could be the cupola going 100mph. πŸ˜„
          Also, I notice in SU........selecting the shadow string fix does not require a style update (even so I did update the style(s))
          & thanks for looking into it.
          C
            You could be right on the cupola.
            I'm starting to look into the problem but I have to find a model that gives me the shadow issue in the first place.
            • C
              Charlie__V
              Request for moderator to move this thread to the LO Bug forum as I have a least one other confirmed case (via private message)
              Or should I re-post there?
              Thanks,
              Charlie
                I moved it, Charlie. I also reported the bug directly to the LayOut team.
