    Trouble starting SU
    4 Posts 2 Posters 338 Views 2 Watching
    • PatrickDP
      PatrickD
      Hi, can anyone advise me on a problem I can't resolve? When I launch SU I get a bugsplat every time. A couple of days ago I downloaded Render[in] 2 after receiving an email from them about the latest version.
      It seemed to make SU unstable and after a couple of trial renders I un-installed the programme completely. Since then I cannot start SU. My question is should I re-install Su and will all my plugins (of which there are many!!) remain. Do I need to save the plugins elsewhere and reinstall them one by one?
      I'm using SU Pro8 (latest version) on a windows XP platform.
      Any help would be appreciated.
      Many thanks
      Patrick Doyle
      As for the future of this forum - I learned how to use Sketchup properly on here and all the hints, tutorials etc have been invaluable. I would hate to see it disappear.
      • GaieusG
        Hi Patrick,
        I would first wade through all my plugin folder to remove any renderin related rb (or rbs) file manually. Uninstalling the application itself may not remove these files, too.
        If SU is still unstable, you can safely reinstall it and all your custom added plugins should remain intact.
        As for the forums - it won't disappear. πŸ˜‰
        • PatrickDP
          PatrickD
          Many thanks Gaieus.
          Appreciate your help as always ;o)
          • PatrickDP
            PatrickD
            @gaieus said:
            Hi Patrick,
            **As for the forums - it won't disappear. πŸ˜‰
            Hi Gaieus
            just an update to let you know how it went! I did as you said and removed all render related rb files and it appears to have done the trick. I did not have to re-install SU so maybe I think that Render[in] 2 clashed with my other render programs, I had Podium and Shaderlight installed. Anyhow all's well and thanks again for your help.
            Thanks also to Annsi and Catamountain from the google forum for taking the time to reply to my call for help!
