    Hello!
    5 Posts 4 Posters 257 Views 4 Watching
      cel
      hi! i'm new to sketchup, trying to find a way to do things like polyline in autocad with combination of lines and arcs. πŸ˜„
        You must draw line then curve (or arc...), then line, etc.
        At the end merge them with this indispensable plugin : Weld
        • pbacotP Offline
          Welcome!
          Why Polylines?
            cel
            @pbacot said:
            Welcome!
            Why Polylines?
            Thank you guys for the suggestions. The model needs to be in sketchup to be viewed by others. I'm an acad user 2d-3d so I did most of my models in autocad, then xref to max or sometimes export to other program. The model is basically a site from dwg and I'm trying to find a way to quickly raise the pavements, islands, etc. in sketchup. I draw lines, triangulate, scratch head trying to find where are the breaks along the lines waiting for sketchup to make faces then either remove or soften where necessary. Anyways, I 'boundary' in acad most of the areas to be raised, poly where I know acad won't extrude. Brought the model in sketchup, add materials and that's it.
            πŸ˜„
            • brookefoxB Offline
              brookefox
              The more specific the question and the more informative the subject line (RE: hello!), the happier the outcome, all things being equal, maybe.
              ~ Brooke
