    UV meshes
    4 Posts 4 Posters 625 Views 4 Watching
    • Z
      zook247
      Is there any plugin that will apply UV mesh geometry to surfaces including non planar surfaces and faces of solids? Artisan does not appear to do this nor does anything else I have found. SketchUV only appears to apply texture maps. Does anything like this exist in the SU universe? Thanks
      • mitcorbM
        mitcorb
        ThomThom has been working on one or two or three. Pixero, I believe, has something. The Plugins Index can be searched with keywords such as "UV". Check at Ruby Library Depot for any others I know I missed.
        • thomthomT
          You want to map non-planar surfaces?
          "Apply UV mesh" - this confused me. Is there something called a "UV mesh"?
          • R
            redlerred7
            I think he means a tool for normal mapping, bump mapping or something similar to that which, when applied to a surface, will deform and add vertexes to the mesh according to the map?
            or perhaps a real-time render plugin that makes it look that way even though it isn't?
            I'm not sure myself
