    Convert disoriented group copies into component instances
    3 Posts 2 Posters 312 Views 2 Watching
    • brookefoxB
      brookefox
      The faces are identical except for their locations. I want them to be the same component (that is, copies of the same component), but so far have not succeeded. Is there an easy way. When I group each face with its edges they are all different groups, not copies of the same. I know I can place a component onto each face and then edit that to be what I want but I'd like something quicker if possible.
      ~ Brooke
        Maybe all this can help you πŸ˜‰
        Loose2group By Chris Fullmer
        Transform any element in group
        All codes by TIG to write in the Ruby Consol
        Objects of a selection in components
        m=Sketchup.active_model;
        m.start_operation("Faces>Compos");
        n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e.all_connected);
        g.to_component.definition.name="FaceSet#1")if e.valid? and e.parent==n.parent and e.class==Sketchup;;Face};
        m.commit_operation
        http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=15209;image
        Faces in components
        m.selection.to_a.each{|e|(g=n.add_group(e);
        g.to_component.definition.name="Face#1")if e.class==Sketchup;;Face}
        http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=15210;image
        http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=15211;image
        Faces in groups
        m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|n.add_group(e)if e.class==Sketchup;;Face};
        http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=15223;image
        • brookefoxB
          brookefox
          Merci, Pilou. I don't think I need Chris' PI for this as I have no problem selecting the faces that I want. I'm not sure how the TIG code bits help, either. I want each face or each face group to be made into an instance of the same component.
          Your mark-up tool is very nice, though. Is it available in English?
          ~ Brooke
