    Animating a push-pull
    5 Posts 3 Posters 1.5k Views 3 Watching
      altab
      Hi!
      I would like to know if there is any way ( function/ ruby / plugin) that can create an animation for a push pulled box for example , instead of scene
      let's say I have a box which is 3m in height and would like to have it in 6m in the final result. I would like to see an animation that reproduce the pushpulling of the 3m diffrence
      Hope it's clear.
      • P Offline
        Yes you can! ☀
        It's with section tool that you can make that! 🤓
        Just take a box against a house! 😄
        [flash=420,315:15ymmzrv]http://www.youtube.com/v/-sQ-7dt95yw[/flash:15ymmzrv]
          jeff hammond
          if you have sketchup pro, you could do it with a dynamic component and animate the on click function..
          (click on the box and it will show the extrusion happen as a smooth animation instead of just jumping from one position to the other)
          dotdotdot
            altab
            Pilou: that's could be a solution but for massing, I would rather prefer a solid box instead of an empty one. ( as it results from the section )
            Jeff: I'm not that keen on dynamic componant...and As I'm a sketchup free version user...
            I think I should have named this thread deformation animation.
            let say changing the position of the object. from a to b and sketchup could autmaticaly create the intermediary position of the object.
            a second example would be: I want to deform a cylinder. in whih the upper cirle change in scale and become bigger than the base.
            • P Offline
              Another thing : with the plugin Mover 😄
              (this is Mover 2 : I have made the animation with Mover 0 )
              I believe than you can't see the animation if Mover is not installed
              mover.skp
