    Why is my Group deleted while trying to add entities to it?
    20 Posts 6 Posters 1.1k Views 6 Watching
      tiktuk
      Hi all,
      I am trying to create a script for creating struts for models of geodesic domes. I do this by iterating over all edges in a model of a geodome and create boxes along the edges. I have gotten all this to work, but for convenience I would like to add all my created boxes to a new group. This fails in the second iteration of the loop, with this message:
      Error; #<TypeError; reference to deleted Group>
      geodome_frame.rb;58;in `entities'
      geodome_frame.rb;58;in `create_frame'
      geodome_frame.rb;53;in `each'
      geodome_frame.rb;53;in `create_frame'
      geodome_frame.rb;115;in `main'
      geodome_frame.rb;84
      geodome_frame.rb;57;in `call'
      geodome_frame.rb;57
      The frame is created if I uncomment the code that adds all struts to a group.
      Here is the relevant code:
      <span class="syntaxdefault"></span><span class="syntaxcomment"># Create a strut (as a box in a group)<br /># along an edge, facing a center point.<br /></span><span class="syntaxdefault">def create_strut edge</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> center</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> size<br />    entities </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />    width</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> depth </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> size<br />    <br />    vec_to_center </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vector_to center<br />    plane_intersecting_with_center </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">fit_plane_to_points center</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">end</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position<br />    <br />    </span><span class="syntaxcomment"># We need a vector in the plane of the top of the strut.<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># It is the same as the normal to the plane intersecting with the center<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># which is the same as the three first values in the plane we just calculated.<br /></span><span class="syntaxdefault">    width_vec </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Vector3d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">new plane_intersecting_with_center</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0..2</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    width_vec</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> width </span><span class="syntaxkeyword">/</span><span class="syntaxdefault"> 2<br />    <br />    </span><span class="syntaxcomment"># We add half a strut-width to the end points<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># of the edge to get the corners of the top of the strut.<br /></span><span class="syntaxdefault">    e1 </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> width_vec<br />    e2 </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> width_vec<br />    e3 </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">end</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> width_vec<br />    e4 </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">end</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position </span><span class="syntaxkeyword">+</span><span class="syntaxdefault"> width_vec<br />    <br />    </span><span class="syntaxcomment"># We add a group for the strut and create the strut top face<br /></span><span class="syntaxdefault">    strut_group </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group<br />    strut_top_rect </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">e1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> e2</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> e3</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> e4</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">    strut_top_face </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> strut_group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face strut_top_rect<br />    <br />    </span><span class="syntaxcomment"># Push pull the top face to create the final strut<br /></span><span class="syntaxdefault">    strut_top_face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull </span><span class="syntaxkeyword">-</span><span class="syntaxdefault">depth<br />    <br />    return strut_group<br />end<br /><br /></span><span class="syntaxcomment"># Loop through all edges in the current selection and<br /># create struts. And add all the struts to a group.<br /></span><span class="syntaxdefault">def create_frame edges</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> center</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> size<br />    frame_group </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group<br />    frame_group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">'Geodome frame'<br /></span><span class="syntaxdefault">    for edge in edges<br />        puts frame_group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name<br />        puts frame_group<br />        strut </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> create_strut edge</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> center</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> size<br />        </span><span class="syntaxcomment"># strut.name = <br /></span><span class="syntaxdefault">        frame_group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group strut<br />    end<br />end</span>
      The entire script is here: https://bitbucket.org/tiktuk/geodome-frames-for-su/src/86808fce358a/geodome_frame.rb .
      If you would like to reproduce:
      1. Install the plugin as usual.
      2. Select some geometry including edges (doesn't have to be a geodome model) for this test.
      3. Choose Create geodome frame from the plugin menu.
      Any ideas..?
        Where in the script does the error occur?
        [off:1hcvswxb]Btw - you should wrap your plugin in a module in order to contain it to its own namespace.
        Read more: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/[/off:1hcvswxb]
          One thing to note when using the Ruby API:
          When grouping, add the group and add the entities directly to the new group.
          This is somewhat different from what you do when modelling where you make the faces/edge etc and then group it.
            [off:1l6p55ob] Sketchup.active_model.start_operation 'Geodome frame'
            Set the second argument, disable_ui to true for speed improvements.
            https://developers.google.com/sketchup/docs/ourdoc/model#start_operation[/off:1l6p55ob]
              [off:ujkahpgr]Instead of this: Sketchup.active_model.entities
              Use this: Sketchup.active_model.active_entities
              That way the geometry is added to the currently open group or component.[/off:ujkahpgr]
                tiktuk
                I have updated the post to include the full error message.
                [off:56wfnlq5]Btw - you should wrap your plugin in a module in order to contain it to its own namespace.
                Read more: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/[/off:56wfnlq5]
                Great, will look into that! And thanks for all your other tips as well 😄 .
                  Only ever use entities.add_group(ents) when 'entities' is the 'model.active_entities' and 'ents' are also in the 'model.active_entities'...
                  Something like...
                  frame_group = Sketchup.active_model.active_entities.add_group() for edge in edges frame_group.entities.add_group(self.create_strut(edge,center,size)) end
                  might be better...
                    Error line doesn't match anything in the BitBucket repository... ❓
                      I'm guessing it refer to line 58. I'm pretty sure it's because you make the containing group after you make the child entities. Refactor the code so you always create the container first - and then add the entities to the container.
                        tiktuk
                        Sorry, the file was out of sync, yes. Corrected.
                        Looking into your suggestions now!
                          tiktuk
                          strut = create_strut edge, center, size frame_group.entities.add_group strut
                          I think you are onto something there. I just noticed that I am creating an extra group in that line, that I don't want or need. create_strut is already returning a group and I have used add_group strut to add that group to my frame_group but while doing that I am creating another group.
                          How do I add an existing entity (a group in this instance), to an existing group? I can't find any methods for that.
                            tiktuk
                            Something like...
                            might be better...
                            Thanks TIG. Did not solve this problem but learning about 'active_entities' was very useful. Was wondering why my struts were being created outside the active component before..
                            • Dan RathbunD Offline
                              Dan Rathbun
                              Above:
                              delete line 44
                              change line 42 to:
                              create_strut edge, center, size, frame_group
                              change line 3 to:
                              def create_strut edge, center, size, frame_group
                              change line 4 to:
                              entities = frame_group.entities
                              I'm not here much anymore.
                              • K Offline
                                kwalkerman
                                I'm not aware of any way to do this directly. If it's a group you want to add you can say:
                                new_group.entities.add_instance original_group.entities.parent
                                (original_group.entities.parent will give you the original group's definition, so you add it like you're adding a component instance)
                                as far as adding individual items to a group, you can do it this way, but it's a little iffy:
                                entities_i_want_to_add = []   #array of entities you want to add to the new group
                                new_group = entities.add_group entities_i_want_to_add
                                then I guess you could find the definition of this new group and add it to whatever entities collection you want, then explode the original
                                The most foolproof way to add entities to a group is to add the raw geometry using Entities.add_edges and Entities.add_face. You'd also need to copy the materials and any attributes you wanted to go along with them.
                                  As Karen said...
                                  You can replicate the faces, edges etc inside a new group [erasing the originals if desired], but you ought to include all materials, layers, smoothed/softened/hidden-settings and attributes etc to make a perfect clone.
                                  You can 'safely' use group=entities.add_group(array_of_stuff) BUT only if the new group and all of the elements in the array are in the same 'context' AND that is the model.active_entities... you can check for that, or if for example you are working on a preselection you know that it is the active_entities, so this will work...
                                  new_group=model.active_entities.add_group(model.selection.to_a)
                                  Then you could 'move' that into any other group/component's entities by getting a reference to its definition [components, groups and images are each instances of variations of a 'definition'].
                                  Let's assume you have another group called 'receiver_group'...
                                  tr=Geom::Transformation.new() new_group_clone=receiver_group.entities.add_instance(new_group.entities.parent, tr)
                                  So the selection has been grouped, that group has been cloned inside another group.
                                  To tidy up use new_group.erase! - you could also use new_group_clone.explode so the selection is loose inside the 'receiver_group'...
                                    tiktuk
                                    Thanks everybody, this forum is splendid, got it working thanks to your explanations 👍 . Ended up just collecting the groups in an array an creating a group with that. Works perfectly.
                                    <span class="syntaxdefault">def&nbsp;create_frame&nbsp;edges</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">center</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">size<br />&nbsp;&nbsp;all_struts&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_with_index&nbsp;</span><span class="syntaxkeyword">{&nbsp;|&nbsp;</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">index&nbsp;</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">strut&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">create_strut&nbsp;edge</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">center</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">size<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;props&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">strut_properties&nbsp;edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;strut</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">props</span><span class="syntaxkeyword">[</span><span class="syntaxstring">"name"</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">strut</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">props</span><span class="syntaxkeyword">[</span><span class="syntaxstring">"color"</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">all_struts&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">strut<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">frame_group&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group&nbsp;all_struts<br />&nbsp;&nbsp;&nbsp;&nbsp;frame_group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"Geodome&nbsp;frame"<br /></span><span class="syntaxdefault">end</span>
                                    I see that your idea would work too, Dan, thanks!
                                      Dan Rathbun
                                      Your welcome.
                                      It is a normal way to pass the context into a method, that creates geometry, so that the method can create the geometry in any context (model or group or component.)
                                      It makes your methods more flexible, so that they can be reused for multiple commands and plugins.
                                        I second what Dan said.
                                        When you model in SketchUp you draw then group.
                                        When you use the API you make the group and then draw entities within that group. It's the clean and safe way of grouping. It's also faster, because you add the entities directly into the context where you want then. If you take existing geometry and group them it takes extra processing to move them.
                                          @th3lurker said:
                                          Also, even if you don't use it, group.add_faces_from_mesh and group.fill_from_mesh seem to delete everything existent in that group.
                                          Only group.fill_from_mesh - as described in the API docs for the methods.
                                            th3lurker
                                            Also, even if you don't use it, group.entities.add_faces_from_mesh and group.entities.fill_from_mesh seem to delete everything existent in that group.
                                            Edit: thomthom corrected me, sorry. Also, i wrote group.fill_from_mesh instead of group.ENTITIES.fill_from_mesh.
                                            I'm going to crawl back to my hole now, one post, two mistakes is quite embarrassing. 😢
